Green LED not blinking
I have simjet 2300,at full throttle the green LED does not blink any more.I have cleaned the filter and still no change, could there be a problem with the fuel pump.
ON, CANADA
Hi Wideopen
It's possible that there may be a problem with the pump, but I would like to check something first. Do you have an IR Handheld unit? If so, can you tell me the rpm at full throttle? Have you changed any radio settings?
Sincerely,
Ed
Sincerely,
Ed
ON, CANADA
Hi Wideopen
Thanks for the info. Two more questions, do you have a FOD screen on the engine. Also, can you give me the engine serial number and the type of pump.
Sincerely,
Ed
Sincerely,
Ed
