 skymaster F-16 1/6 scale bell or bypass??? >
Old 06-24-2013 | 04:44 AM
My Feedback: (224)
Default skymaster F-16 1/6 scale bell or bypass???
Hey Guys,
I'am trying to make up my mind on my 1/6 scale F-16 if I should use the Bell or bypass .
I have never used one on any of my jets before and am using a jetcat 160sx
On The skymaster F-16 the bell sits back into the fuse I think it might go on fire with a hot start .
Need to know what you guys are doing and what is the way to go with this onel.
Old 06-24-2013 | 05:25 AM
Default RE: skymaster F-16 1/6 scale bell or bypass???
Hi Ray, how are you..
I have used a bellmouths on 160's with very good results, no problems at all
Hans
Old 06-24-2013 | 06:39 AM
AndyAndrews's Avatar
ORIGINAL: alumaman
Hey Guys,
Bellmouth is all I have ever used on Skymaster F-16s. You are correct though. If you have a wet start you do risk damaging the airframe. If you put BVM heat shield in the area above the bellmouth, it will be fine though.
Both types of installs work fine though. I've become fond of the full bypass as of late. If you use the bellmouth, I do recommend at least using a half bypass to help prevent FOD from getting into your tubing from the bottom since it is pretty much exposed on the F-16.
Old 06-24-2013 | 08:22 AM
Flynstuff's Avatar
My Feedback: (29)
The bypass will also help to keep the energy up on the jet, less power to go fast.. However it will slow down better, faster without it and the hi-alpha stuff will be easier to achieve . Iv had both setups and prefer the non bypass.
With the bell mouth setup you do take a chance of doing damage if you get a hot start and the paint will bubble. Yo can also use the heat blanket that BVM sells to go around the inside of fuse.
Old 06-25-2013 | 01:57 AM
My Feedback: (224)
Hi Hans,
I'am good did you fly the Rafale yet?? Ray
Old 06-25-2013 | 02:00 AM
My Feedback: (224)
Thanks for the reply do you have a few pictures of your turbine pipe install and placement of the turbine ??
Ray
Old 06-25-2013 | 05:12 AM
icepilot's Avatar
I am on my third SM F-16 1:6 now, and have never used a bypass or a bellmouth. I find that
they both represent a possible problem in different situations, and have chosen to fly without
them. I simply have about a 1" opening between the end of the turbine cone and the start of
the pipe, this gives me a clear vision of what is going on during startup, and a great possibility
to observe and put out a potential fire during a wet start.
I have used G-Booster 160, Jetcat P180 and the last one flies with a Behotec 220 turbine, and
it's just a great plane to fly regardsless of the power option!
ID:	1894918   Click image for larger version
Old 06-25-2013 | 05:48 AM
Tor, are you sure about that.
Your F-22 had a bellmouth , right? and you dont have that same setup in the F-16?
Hans
Old 06-25-2013 | 06:26 AM
Flynstuff's Avatar
My Feedback: (29)
I'm using a Kingtech 170 and a Tamjets pipe. I'm only running the two saddle tanks and UAT. Light setup and the performance is outstanding. Ill upload pictures later tonight. I would recommend you try with just the saddle tanks with your 160. Flight time will be about 6min and it will be light.
Iv had 5 Skymaster 1/6 F-16's all with engines ranging from 160's - 220's and like Tor says, they fly great with every motor option. The fun thing about the big engines is the slow Hi alpha to vertical climb-out. But is heavier due to the extra fuel and weight of the engine..
Long time Tor... Hope all is well and im glad your still enjoying your Skymaster 1/6 F-16. I will always have one in my hangar....
Old 06-25-2013 | 11:00 AM
icepilot's Avatar
Hans, I never had an F-22, only F-16's, F-15's and a Panther + some smaller jets!
Old 06-25-2013 | 11:15 AM
Tor you're right, sorry ! I mistook you for Stig, haha....getting old[&:]
