Futaba Radios Direct support forum Ask any questions you may have about Futaba radios and product here and get answers direct from Futaba
8UAF glitch/malfuntion?
Old 09-26-2003 | 11:15 AM
Default 8UAF glitch/malfuntion?
I have a 8uaf that has a servo hooked up to chn 8 as a trigger for a camera. Was working fine untill today. I linked- chn8-chn8, then linked to switch f in the down position. There was no ofset or anything I changed. The switch would read "on" or "off", wasnt set to inh. I now adjusted the ofset and had to reverse the servo. It works now but Im worried there may be problems in the future, on inportant chanels. Has anyone experenced "glitchs" or strandge malfuctions in linking certain functions to switches on the 8uaf? Thanks for any help, this is very important as I could loose control of my model.
Old 10-06-2003 | 02:41 PM
Default RE: 8UAF glitch/malfuntion?
Hi SpaceCase,
You should never see any type of glitching due to programming on your transmitter.
If you are referring to odd or unexpected servo movements, it may be that you have another Pmix active that is causing your problems. If in doubt, it would be suggested to go into a completely blank model on your transmitter and set your mix up there. If there is no unusual behavior seen then your transmitter is fine, and again what you are noting may be due to another active Pmix.
I hope you find this information helpful. You can also reach our Futaba support technical team at 217-398-8970, or via fax at 217-398-7721.
Sincerely,
Krysta
Lead Futaba Customer Service and Programming Technician
Also you may want to check our Website at (www.futaba-rc.com)
