Glow Ignitor - Stupid Question
Hey guys, I just bought a Factory Team Glow Ignitor. The blue aluminum one with the indicator on the top. The stupid question is, how long do I charge it for? There are no directions or documentation of any kind with it. The charger it came with is a 150 mAh charger and I do not know how many mHa the battery is. Any ideas?
One more thing. I have heard that the indicator on the top is NOT a charge indicator. What is it then? Thanks!!
ORIGINAL: benzzyo5
i would just charge it for 10 hours. do it over night. also that indicator/ meter at the top is for how much juice is left in it
No its not that indicare is to show you how much life you glow plug still has.........once red ur glow plug is a gonner!!!
ohh,....sorry. i kind of guessed..i never had one like that though. but anyway they last a while.i use mine all the time and it lasts me months
My Feedback: (9)
NY
the indicator on the top has nothing to do with the power in the glow starter. I have the saw one of some kind of variation. if it is in the red area is mean you glow plug need to be changed if its in teh green its good and if its in the middle it it good to but will need changing soon. I realy like it becuase i used to change my plugs none stop.
ORIGINAL: D-Fly
From the Tower description.
This is a Glow Plug Igniter with Cap Meter and AC Charger from HPI Racing.
The glow starter is used to heat a glow plug while starting an engine.
FEATURES: Hot pink machined and knurled aluminum battery holder.
NiCd cell provides higher voltage under a load than an alkaline cell.
Meter has green area for charged and red area for must recharge.
Spring-loaded locking socket design.
Comes on a picture instruction header card.
INCLUDES: One Glow Starter with Cap Volt Meter.
One Panasonic 1.2volt, 1300mAh sub-C size NiCd Battery
One AC Charger (United States Standard)
The indicator on top is double duty it lets you know if the plug is dead or the glow lgniter is dead either way it will read red. If it reads red I always take a new glowplug and test it on my igniter if it doesnt glow orange I know the igniter is dead. Recharge and test again.
OH
i know on mine, the indicator has nothing to do with the battery
it just shows you on a scale of how good your glow plug is lighting up... if it is low on the meter than you need a new glow plug.. if it does it with a new plug then you need to recharge.. i usually just charge it like sunday night when i go to bed, and dont get it till the monring or after school.
ORIGINAL: evaderstbasher
What ignitor do you use?
AZ
ORIGINAL: AlucardTepes
Ok guys I will make this real simple on the charging time. I also have the Factory Team Glow Ignitor and if yours
is the same as mine it came with a 3300mAh battery and the 150mAh charger. To get the proper charge time divide
the battery's capacity by the mAh rating of the charger. 3300/150= 22 hours for a full charge. I also found a 190mAh
charger laying around my tool box so this cut charging time down to a little over 17 hours. My son has a ignitor that has
a 1500mAh battery and with the 190mAh charger the battery is full at 7 1/2 hours. Simple math! By the way the meter
will show red as stated above in another thread if the glow plug is bad or the ignitor battery is dead. Hope this helps !!
If you are not smelling nitro fumes and listening to the sweet song your not LIVING!!
