 What voltage for the kerosene pump? >
Old 06-30-2007 | 11:19 AM
Default What voltage for the kerosene pump?
Hi,
I have purchased a kerosene pump as that used on the Jersey Modeler Fuel cans
to what voltage has to work?
Thanks in advance
Best Regards
Old 06-30-2007 | 11:33 AM
Shok's Avatar
My Feedback: (28)
Default RE: What voltage for the kerosene pump?
I have not used that exact pump, but the one I have is 12 volts, but I run it at 6 volts too keep the pressure down when fueling
Old 06-30-2007 | 12:27 PM
i use the same pump and use a 7.2v pack from a JetCat ECU.
kc
Old 06-30-2007 | 12:46 PM
ORIGINAL: Shok
Thanks, Ronnie...
Regards
Old 06-30-2007 | 12:48 PM
ORIGINAL: KC36330
kc
Hi Kc,
many thanks for your reply.
What amperage?
Thanks in advance
Best Regards
Old 06-30-2007 | 01:24 PM
never checked it to tell the truth
kc
Old 06-30-2007 | 01:35 PM
ORIGINAL: KC36330
kc
I intended the batteries amperage...
Regards
Old 06-30-2007 | 01:48 PM
grbaker's Avatar
My Feedback: (29)
I use a 5 cell NiMH 4400 mah pack on mine.
Old 06-30-2007 | 02:57 PM
Thank you Gary,
Best Regards
Old 06-30-2007 | 03:28 PM
Some have found that running this pump on 6.0 or even 4.8 V will not decrease the fill time much (measured fill time doesn't appear linear to voltage), but it avoids bulging tanks; decreasing the likelihood of a split in moulded tanks later on in the jet's life. 7.2 V is an absolute max for our application...
Kelly
Old 06-30-2007 | 04:08 PM
Many thanks Kelly...
Best Regards
Old 06-30-2007 | 05:06 PM
I USED A RHEOSTAT ON MINE
ID:	714210   Click image for larger version
Old 06-30-2007 | 05:39 PM
ORIGINAL: S_Ciambra
Regards
1250mah
kc
Old 06-30-2007 | 06:56 PM
Wayne22's Avatar
Just use a cheap 6 cell car pack and it will run all weekend.... I got one that Kelly built up and couldn't be happier with it!!
Old 06-30-2007 | 11:42 PM
GoeKeli's Avatar
My Feedback: (18)
Gary, I use 5 cell as well with a return tube from planes tank vent back to fuel can vent, in a closed loop. I think I pumped a whole 5 gallons one day and when I recharged the 3800nimh it took 1400mah. Pretty easy goin.
It does take longer but there is no need to watch the process and it gets done without tank splits Like Kelly mentioned.
ORIGINAL: grbaker
Copcat, I like this fuel container, where did you get it? I have a dark blue one from JM and it is darn hard for me to see the level inside. Anybody know?
Joe
Old 07-01-2007 | 01:21 AM
SECRET AGENT's Avatar
My Feedback: (18)
Man, that thing is slicker than snail snot.
Old 07-01-2007 | 06:49 AM
Kevin Greene's Avatar
My Feedback: (85)
I've got one of the first Jersey Modeler fuel cans. It has a 9.6 volt pack and it is way too much...I haven't split any tanks as I use all large fuel line on EVERYTHING but I did notice that during a hot refueling the turbine RPM increased substantially when the fuel pump switch was turned on....I was putting so much pressure on the system that I was over-running the turbine pump..[:@]...If left in this condition for very long (Long enough to fill the tanks) you can over-temp the turbine...I won't ever hot fuel again until I lower the voltage to the fuel can pump...
Speaking of fuel cans---Does anyone know where to purchase a "Low Boy" fuel can so that I can install my current Jersey Modeler electronics to the new Low Boy???
Kevin
Old 07-01-2007 | 03:06 PM
seanreit's Avatar
My Feedback: (60)
Like this?
ID:	714661   Click image for larger version
ID:	714662   Click image for larger version
Old 07-01-2007 | 03:08 PM
seanreit's Avatar
My Feedback: (60)
http://www.rcuniverse.com/forum/m_60...tm.htm#6048582
Old 07-31-2007 | 10:54 PM
My Feedback: (10)
Where are you guys getting that pump?
Old 07-31-2007 | 11:09 PM
seanreit's Avatar
My Feedback: (60)
www.dreamworksrc.com
www.greylor.com
Old 08-01-2007 | 12:05 AM
GSR
My Feedback: (145)
I used to run 6 cells and would get a lot of static with a ZAP everytime I switched off the pump. I went to a 4 cell pack and I have not been zapped since. The fill time is a bit longer than with 6cells, but not much. Scott
