 JetLegend F-16 Kit Build >
Old 07-20-2007 | 10:37 AM
My Feedback: (9)
Default JetLegend F-16 Kit Build
I tell you , That the JetLegend Kit is Nice But it is absolutely without any Instructions. If you aren't Careful, you could end up with a number of problems that would be difficult to overcome. Does anyone know if their is room to set the fuel cells in foam. without deforming the fuse? Should they float in foam or is a good silicone OK?
Any other suggestions or Ideas on the build of this kit including sequence will be very much appreciated.
Old 07-26-2007 | 09:40 AM
My Feedback: (9)
Default RE: Let Legands F-16 Kit Build
Main doors are on with Offset hinges. It took all night to do the first one and 20 minutes to do the other side.
Sorry for the Cell Phone shots, I used a single pin with all 3 hinges on it. Doors are bolted to the hinge. for removal.
ID:	730251   Click image for larger version
ID:	730252   Click image for larger version
Old 07-26-2007 | 12:00 PM
Hi drdoom,
I found that the turbine rails hold the tank securely without additional “fixativeâ€. Just a layer of protective material over the shortened wing fixing bracket bolts being more than adequate.
Checkout RCJI June/July and Aug/Sept issues for a kit review and also the thread here on RCU
http://www.rcuniverse.com/forum/fb.a...gend%2Cf%2D168
HTH
Eric
ORIGINAL: drdoom
Old 07-27-2007 | 01:46 PM
My Feedback: (9)
Protecting the tank from the wing mount is a great idea. Thanks
I poped the tanks in this morning to se how much space they took up.
It is not going to be easy to find room for the door cylinders. How well did your main doors fit?
ID:	730854   Click image for larger version
ID:	730855   Click image for larger version
Old 07-27-2007 | 02:08 PM
Hi drdoom,
Fit of the main doors was very good. It took me a long time to fit the doors and cylinders as they were a first for me.
Eric
ORIGINAL: drdoom
Old 07-27-2007 | 03:31 PM
My Feedback: (9)
Does that air cylinder pillar protrude up into the air intake? Your installation of the air cylinders looks very neat.
Old 07-27-2007 | 11:43 PM
Wayne22's Avatar
Do they supply an air duct to the front of the turbine, like the old ones ???? The LG looks super!!
Old 07-29-2007 | 02:11 PM
Hi drdoom,
I shortened the removable ducting by approx 3†to accommodate the cylinder support. The ducting is still secure because of the long overlap with the fixed ducting and the screw holding them together. The turbine still gets plenty of air.
Five more flights today against a blue sky for a change!
Rgds,
Eric
ORIGINAL: drdoom
Old 07-31-2007 | 11:14 AM
My Feedback: (9)
ORIGINAL: Wayne22
Yes It comes with a NICE 2 piece inlet liner and an Inlet lip. I will make mine removable so I can get to things inside.
Eric: Can you post a Pix of your nose cylinder? Please.
Old 07-31-2007 | 11:40 AM
Hi drdoom,
Yes sure. Have to take one first though.
In the mean time have you seen the photos by Lasse Palm?
http://www.rcuniverse.com/forum/m_58...4/key_/tm.htm#
Rgds,
Eric
ORIGINAL: drdoom
Old 07-31-2007 | 01:27 PM
My Feedback: (9)
I looked those over very well before I begain building. But you can never get too many ideas.
I got the kit instead of the arf so Nothing was installed. I have had a lot of fun putting this togather.
I bought Jet Model Products Air accumulator for the doors and the gear. distributes equal air to each component at the same time.
I am also using the JMP sequencer for the gear and doors. Using a JR 10X with the DS-8711 servos on the horozontal stabs.
p-70 for power.
Old 07-31-2007 | 01:49 PM
Hi drdoom,
As you will see from the (not very good) photos I cut a little of the nose wheel cassette away to accommodate the door cylinder.
My F16 at 17.5lb dry is fast with the Wren 54 MK3 at 14.5lbf. Yours with the P70 should be very interesting!
Rgds,
Eric
ORIGINAL: drdoom
p-70 for power.
ID:	733072   Click image for larger version
Old 08-01-2007 | 10:44 AM
My Feedback: (9)
I got my nose gear door on last night and have it swinging as it should.
I wish I had a smaller set of door cylinders. Ill do the mains as you have.
Not going to be fun doing the nose gear door Link and cylinder.
Iv'e turned back the RPM pn the P-70. Ill bet their is not that much Differnce.
I was hoping for a very fast spool time, Not more speed. Before the kit arrived I had purchased
an Artes Falcon 100 for it, Because it is about the same diameter as the p-80 and I thought it would fit.
Well when it showed I knew it was way to big. so Its on the bench.
Old 08-01-2007 | 04:20 PM
My Feedback: (49)
drdoom,
Are you saying that the P-70 fits and the Falcon doesn't? According to the specs there is only one mm. diference in the diameters.
P-80 4.4" (112 mm.) dia.
P-70 3.7" (97 mm.) dia.
Falcon 3.86" (98 mm.) dia.
Joe
Old 08-02-2007 | 04:11 PM
My Feedback: (9)
No the Artes will fit, and I did the same thing that you did, I compaired the diameter of those turbines, and Bought the Falcon 100 because of power
for the $$$ spent. and I liked the warrenty. But is is Much Heavier and way to much power. So I dicided to go with a P-70 Because I still wanted at least 17 lbs of thrust.
Also Believe that if you do use the Artes Falcon , You will need a larger Diameter tail pipe.
The Jet Legend F-16 is a Small Jet by todays standard. Another consideration Is that extra weight on that scale landing gear. It has built in dampning and You don't want it smashed all the way down while just sitting still.
Old 08-02-2007 | 04:26 PM
My Feedback: (49)
Thanks. I'm considering a JL F-16. Sounds like my Wren 54 might be a better choice than my Falcon. The Wren engine weighs about 2 lbs. and the Falcon about 3 lbs. Depending on what you have to do to balance it a pound one way or another shouldn't break it.
By the way what is the tailpipe diameter, at the inlet and at the exit?
Joe
Old 08-02-2007 | 04:46 PM
My Feedback: (9)
Well I finally got a start on the Bondo.[:@].
ID:	734398   Click image for larger version
Old 08-15-2007 | 10:05 AM
My Feedback: (9)
T Minus 22 days and counting.. I don't know If ill will get er done or not.
Stuff keeps breaking a the house. Disposal quit. and Both Garage door springs Broke on the same day???[:'(]
I Should finish this messy process this week. I hope that the gear doors continue to fit after all of this work.
Hatch and Canopy fit well now.
ID:	742547   Click image for larger version
ID:	742548   Click image for larger version
Old 08-15-2007 | 10:45 AM
My Feedback: (49)
drdoom,
Why was the bondo necessary? From the looks of your first few pictures the kit came finished in camo scheme.
Joe
Old 08-15-2007 | 11:08 AM
My Feedback: (9)
Just dooing away with all of the seams. I wanted the hatch, and canopy and Gear doors to fit flawlessly.
I had no way of knowing how well things fit when I ordered ths kit, But It didn't matter Because I Knew that I could make it fit like I wanted it to.
Trust me It will be Nice when it is done. Oh the real reason : I hang out with a guy that is Totally Obsessed with PROFECTION, and He has already Hinted that it also needed to be flawless inside. Tom Cook of Jet model Products..... Wait till you see his Dauntless...
Old 08-16-2007 | 10:07 AM
My Feedback: (9)
Here is the fuse in primer.
ID:	743186   Click image for larger version
ID:	743187   Click image for larger version
Old 08-16-2007 | 10:08 AM
My Feedback: (9)
Fuse and doors.
ID:	743191   Click image for larger version
Old 08-16-2007 | 11:40 AM
SDCrashmaster's Avatar
Let Legands???
Is this a new company? Sounds like it's from France.
Now I thought surely it was just two terrible typos in the thread's title, but sure enough, right in the first sentence of the first post, there it is again...let Legands.
Wow.
Did we mean Jet Legends?
Old 08-16-2007 | 12:23 PM
My Feedback: (9)
ORIGINAL: SDCrashmaster
Let Legands???
Wow.
Sorry Your right . It is Jet Legends.
Old 08-16-2007 | 06:34 PM
causeitflies's Avatar
ORIGINAL: drdoom
Let Legands???
Wow.
No, it's Jet Legend
