Fei Bao : Velox XL !
My Feedback: (10)
New Giant Velox XL
just came in last week before the Jetpower show
i just started working on it , and hopefully will be flying in a week or 2
some details:
Length : 2450MM -96 inch
Span : 2150mm-85 inch
weight of the kit was 6.9 kilo,s - 15 pounds
power needed 80-160N
Wheels Front 75mm
Rear 100MM
Jet-1A Main oleo,s
will keeo you informed about the build and first flights
i will be powering it with a Merlin 170
some details:
Wheels Front 75mm
Rear 100MM
Jet-1A Main oleo,s
My Feedback: (10)
ORIGINAL: john agnew
Sandor
That should be a rocket ship with a Merlin.
My 339 was 23 kg wet and did not lack vertical performance with the Merlin. How much? how soon?
Best regards
John
Sandor
My 339 was 23 kg wet and did not lack vertical performance with the Merlin. How much? how soon?Best regards
John
we will test this one first , and after they are ok , i guess they will hit the market.
i hope promisses are made this time ,we have some changes done like a GIANT fuselage to hold lots of fuel ,and smoke tanks.
i think we can use a UK cider bottle of 3 liters and still put 2 liter bottles aside the big one.
the merlin looks small on this huge thing.
the Landing gear contains the wheels from the MB-339
the front oleo comes standard trailing , the aft oleo,s where strait.
i exchanged them with the jet-1A with the heavy spring.
the jet-1a where specialy designed for them.
here some more pics of the new wing and elevator design..no more hinges!!
Any new info on this bird? Realy seems nice. I am looking my first jet. Thinking to buy Velox XL, Boomerang XL or AVIATION DESIGN Angel. Hard to decide...
ORIGINAL: cel
Any news about the airplane. Do you have any idea regarding the price. Thanks
Right now we are doing the manual and test flight of the plane, production will start in December and all orders will be attended as FIFO, If you need more information about the plane send me an email to [email protected] with your phone number and I will be glad to call you, by the way we speak Portuguese.
Regards,
Wagner
ORIGINAL: cel
OK Wagner. I am already a RCJetmodels customer. You sent me the velox to Alphaville. Any news just let me know. Best Regards.
ORIGINAL: cel
Wagner
Looks good! Particularily in that colour scheme, the fuselage looks deeper in comparison to the Velox with more room inside. What I really want to know is where is the SU27? Can you give us any more info on availability, turbine size, one or two turbines etc.?
Best regards
John
Best regards
John
Wagner
Best regards
John
Wagner
Best regards
John
SU27 still in the bench, LG is finished and they are working on the intake's hatch to access the turbines, she is a twin and I believe that 2XP80 or 2XFalcons will do the job, after we receive the prototype, that is scheduled for the beginning of the next year, we will know better.
Regards,
Alex
You might be able to do that by fitting a single turbine and using a straight pipe. I have seen a couple of twins done this way and it works. The taipipes are close enough together so that assymetric thrust is not a problem.It also gives you plenty of room for a fuel tank in the other engine bay.
John
John
Alex
John
Alex
John
Not in the SU27 there is no room in the fuse to install a single turbine inside, however you can install it outside if you install it inside a fake drop tank.
Wagner
If you can install two turbines in the SU27 (say P80 size) why not one P120 which is the same size as the P80? The single turbine would go in one of the engine bays only, not in the centre like the F15.
John
John
Wagner
John
Wagner
John
Wagner
Trust me, it works, you put your main fuel tank in the other engine bay plus your batteries etc. this takes care of the weight situation. You might have a small off centre balance when the tank is empty but remember your single turbine is very close to the cetreline. The thrust being slightly off centre does not seem to affect yaw from the models I have seen fly.
Here is a good example. David Matthews flew this single engine F18 at the WJM in this configuration. The straight pipe also cuts down the power loss of a bifurcated pipe.
John
John
ORIGINAL: RCJET101
Wagner,
Back to the Velox XL. Any idea what the US price will be? And when are they due to start shipping?
Wagner,
