 Feibao Bae Hawk >
Feibao Bae Hawk
Feibao Bae Hawk
Old 09-30-2007 | 05:02 PM
Achillesfilho's Avatar
Default Feibao Bae Hawk
Has a P-70 enough power to fly the FB Bae Hawk (large )?
Are thise birds (both verions ) already avaliable?
Thanks.
Achilles.
Old 10-01-2007 | 04:22 AM
Default RE: Feibao Bae Hawk
It would be able to fly it.
Certainly you won't get a take-off from grass.
Mine came out at 24lbs dry, so the 70 would be marginal. I fly with a P80 and could do with more.
Steve
Old 10-01-2007 | 11:10 AM
CARS II's Avatar
My Feedback: (7)
I agreed with Steve, the P-70 will be very marginal and you will need lots of runway fo the TO. I will have to say minimun thrust for this airplane should be 20#s, no less.
Old 10-01-2007 | 11:56 AM
Tank you guys.
Old 10-01-2007 | 12:34 PM
My Feedback: (31)
I had a P70 in the first Skymaster Bae Hawk which is the same size as the Feibao and it flew very scale. It had plent of power to get off a paved runnway and would do it in about 450ft. I did not add any of the geardoors so that I could keed it very light. The vertical performance was not that great and would fly around 180MPH, Very clean airframe.
ID:	774192   Click image for larger version
Old 10-01-2007 | 01:18 PM
JohnMac's Avatar
I had a SM Hawk and now have a FB Hawk (although the latter is still in the box.) The original Hawk was first flown with a Wren MW 54. It needed just a little more and it was then flown with a Wren Supersport, which was perfect for scale flying. Of course if you want it to go like an F1-16 then the sky is the limit. The FB Hawk is, so far as I can see, identical to the SM Hawk, except it is a bit heavier. I think it will still be OK with the Supersport.
Of course this engine is light and very economical so there is no need to fill the small tank. Thrust is not the only point to consider, weight is important too, and fuel economy has a big part to play.
Regards,
John
Old 10-01-2007 | 02:13 PM
Ok, i think i will take a chance with the P-70.
Thank you for your help.
Regards.
Achilles.
Old 10-01-2007 | 02:58 PM
CARS II's Avatar
My Feedback: (7)
Good luck and please post some pictures and let us know of your progress. I have a Fei Bao Hawk thread that you can use to post your progress if you like, so we can keep all Hawk jet related posts in one thread for eveyone to read.
Old 10-01-2007 | 03:04 PM
CARS II's Avatar
My Feedback: (7)
If you need any building tips please feel free to ask, there is lots of info an the FB Hawk ( T-45 ) on my thread.
Old 10-01-2007 | 03:31 PM
My Feedback: (31)
Here are a couple of other pictures of the Hawk as you can see no gear doors in the picture in flight. If you are going to build with a P70 watch the weight. If I were going to use that size of a turbine I would go with a Falcon from Artes it puts out 22lbs of thrust and it is the same size as the P70. Also keep in mind that the FeiBao Hawk is a little heavier than skymaster. My original Skymaster Hawk weighed in around 21lbs.
ID:	774305   Click image for larger version
Old 10-01-2007 | 04:00 PM
Ok, as soon as i start to build i will post the pics and share with you my doubts.
Thank you very much.
Regards.
Achilles.
