Evolution 40 GX vs 35 GT
Old 06-17-2008 | 04:34 PM
Mr67Stang's Avatar
Default Evolution 40 GX vs 35 GT
I just saw an ad for the new Evo 40-GX! I am an owner of a 35-GT. The 35-GT is now discontinued and replaced by this 40-GX. I looked up the specs and saw that they share the same demensions and the 40-GX is 1.6 oz lighter. If I had to guess I would say they share the same engine block and head but the 40-GX has a longer stoke and/or bore. Simply said they put a new piston/rod/crank in the old 35 GT and said, "we have a new engine." Kinda like taking a worn out 302 and installing a stoker kit to get a 347. The 35-GT has been accused of being over weight and under powered. I guess this is the answer to those cries. I also surmise that the weight savings of 1.6 oz. comes from a trimmed crank/rod/piston... Bottom line here! Is there a "stroker kit" I can buy for my 35-GT to make it a 40-GX?
References:
[link=http://www.horizonhobby.com/Products/Default.aspx?ProdID=EVOE35GT2]35-GT[/link]
[link=http://www.evolutionengines.com/Products/Default.aspx?ProdID=EVOE40GX]40-GX[/link]
Old 06-17-2008 | 05:46 PM
Default RE: Evolution 40 GX vs 35 GT
No
Old 06-17-2008 | 05:54 PM
My Feedback: (19)
ORIGINAL: Mr67Stang
References:
$500.00????? for a 40 .... Guess I won't be buying one anytime soon.
Old 06-17-2008 | 07:35 PM
Mr67Stang's Avatar
ORIGINAL: pe reivers
No
I was hoping you would come in and tell me/us what the actual differences are. I understand your one word answer is in responce to my question about the availability of a "stoker kit". However, I would have hoped for a more detailed explaination from you pointing out the differences and correcting or confirming my theories. Unfortunately it is imposible to know exactly what your tone is on the subject but it's imediate apearence is that your offended by my comments and do not want to expound upon the benifits of upgrading to the 40-GX as oposed to modifying a 35-GT. I do thank you though for making my decision easier to just make the move to 50cc aircraft and engines and leave these "betweener" engines alone. I will note however that I was happy with the overall quality and reliability of my Evolution gas engine but it will be sold now to fund the purchace of a DA-50.
Old 06-17-2008 | 09:43 PM
wyo69cowboy's Avatar
Eloquent reply, Mr. Stang! LOL I don't know the specs either, but, based on the weight loss, I'm guessing most of the weight loss and cc increase comes from a bigger bore, not a longer stroke. BTW, bet a lot of folks didn't get your 347 stroker reference, but I know I thought of that solution once or twice with my '92 F150 5.0!
Old 06-18-2008 | 06:39 AM
Yes, I was/am a bit offended by the negative attitude of your posts, and no, there is no upgrade possiblilty, unless you consider keeping crank and conrod only whist exchanging all the rest as an upgrade.
The 40 engine was a result from the 35 not being an established engine class, and the overly sturdy design, which resulted in a relative heavy engine. An extra weight that many complained about, except the users of the engine.
I personally complained to MVVS because they adhered to relatively long stroke designs, that results in heavier engines.
So they bored out the case, fitted a larger bore liner, and upgraded the engine into the well established 40cc class.
This resulted in more power in a lighter package.
Old 06-18-2008 | 12:30 PM
Mr67Stang's Avatar
Thank you for explaining the actual differences between the two engines. My original post was actually posted out of excitement that there may be a means of "pepping up" my 35_GT and I love the engine but it will not perform in the aircraft I want to fly that physicaly sized engine in. AeroWorks has a new [link=http://www.aero-works.net/store/detail.aspx?ID=308]35cc Extra 260[/link] that I thought would be ideal for a pepped up Evolution engine thus my excitement for the possibility. Due to the cost of purchacing a new 40cc and still not having anything to put my 35cc into (that I like) my excitement diminished in the second post
Old 06-18-2008 | 01:19 PM
You can pep up the engine, which certainly is not underpowered, by using a decent muffler system, like the MVVS tuned pipe, or a good canister. The 35 with canister muffler took my 18 lbs towplane into towering verticals, just short of a torque roll.
Old 06-18-2008 | 07:31 PM
I just ordered 35GT2 for my H9 P-51 1.50 Frankie. Need a Pitts muffler for this engine inverted. pe reivers,whih one will give me most usable power for this combo??
Old 06-19-2008 | 07:38 AM
here are exhaust data for the engine
rpm exhaust plug prop
6350 3271 20x10 mej
7300 3268 20x10 mej
7650 3268 20x8 apc
6750 3298 20x8 mej
7150 3271 20x8 mej
8300 3268 20x8 mej
6650 3268 21x10 mej
I do have no further data. The 3298 side muffler is no longer produced
As you can see, I have no data on US produced mufflers.
Old 06-21-2008 | 03:12 AM
I have to say my MVVS 35 in my 15 pound GeeBee Y (inverted side muffler) will not pull like my friends DA 50 in his 87" Yak, but for only a 35 my Gee Bee Y's top speed is impressive !!
it's just a damn good engine !!!
