Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Car General Discussions
Cheap easy brake solution? What do you think? >
Old 05-13-2003 | 08:47 AM
Default Cheap easy brake solution? What do you think?
Guys,
Have a look at the diagram I have done below. It shows (sort of) the throttle/brake assembly on my Monster Pirate.
My question is this. At the moment my brake linkage is on the furthest hole on the servo arm as shown.
Now I didn't do advanced maths mechanics, but my theory is that because the power being applied is on the fulcrum (top of servo) that by moving the linkage to the inner most hole on the servo arm (where the dotted line is), I will lose a bit of speed on the brake, but gain more mechanical advantage and hence more braking power from the servo.
I cannot extend the lever at the end of the linkage as it would foul the spur gear.
Do you think this will work?
Old 05-13-2003 | 11:06 AM
In theory yes this should work. It will definately be "easier" for the srvo to apply pressure if you put it on the inner most setting, whether or not that will result in more braking power I don't know.
Old 05-13-2003 | 11:43 AM
you got it right. see that stuff they told you in science class that you swore you would never use acually came in handy.
try moving it a hole at a time to see if it works. as it might not work in the closest hole due to the lack of travel.
Old 05-13-2003 | 12:24 PM
Thanks guys, a few people at work thought I'd got it the wrong way round. They were thinking of levers.
I feel vindicated!!
