Remove old tires from rims
My Feedback: (35)
ORIGINAL: mnrcaerobat
Is there a good way to get old tires off of the rims? These were CA'ed on.
FL
well if the tire is shot than i just cut the tire out save the foam if its in reasonably good shape and take a dremal to the bead of the rim to get the tire lip and glue out
WV
CA
If a tire is worn out, cut the tire close to the bead and soak the tires in acetone for a night or 2. The tires will come off easily. The foams will be toast though. The oven method sucks and the boiling method never really worked for me. Let me rephrase, if you take the worn tires out and take out the foam (only reuse good quality foam, NOT proline!) then the foam will be fine since it is not exposed to acetone. But if you soak the foam in the acetone they will tear easily. I just use a dry coffee container with lid for the acetone and only fill it with acetone about 1/8 of the way since the fumes is what really kills the CA.
Boiling does work somewhat I've used it in trying to salvage 3 tires from rims. 2 tires came off fine (after fighting with them) 3rd one well got totaled its more hit or miss. Also be careful you don't burn your hands with the boiling method. Can I recommend the boiling method? not really its very time consuming (I spent around 40-50 mins a tire) and can be quite painful (hot water shot into the gloves I was using).
Personally like others have said if your not trying to save the tire just cut it off down to the rim ,and dremel the rest off the rim with a fine sanding bit. it will probably be the fastest, easiest, and safest way.
Later on I got to do the opposite I have a rim I don't care about (the hex hub stripped the rim) but the tires almost new. I'm probably gonna just cut the rim up and sand off the nylon
IL
for all the pain in the butt for removing tires from wheels, it is just much easier to replace wheels and tires together .... i might have to try chris's method cause i got some discontinued wheel i dont wanna lose.
CA
ORIGINAL: MCSRacing
VT
ORIGINAL: rollingball
Boil for 10 minutes, then dunk in ice water. CA will be no match for ths meathod. Just about flakes off the rim.
the lug
My Feedback: (197)
MN
ORIGINAL: Chris_RC
Worked great. I just put them in a container with a little acetone and after several days, they pulled off really easy.
Now how do I balance the tires. The rims I have had some glue from a hot glue gun in the bays. Is that a good way?
CA
ORIGINAL: Chris_RC
MT
you don't want to just balance the rim/tires, make sure you mount the tire to the rim first. I don't know if you were planning on balancing just the rim or just the tires, balance them together as a set. I'm only saying this because you asked "Now how do I balance the tires.", which lead me to believe you wanted to balance them separately....(which I guess might work.....? but would be harder overall I think?)
CA
ORIGINAL: Brainanator
you don't want to just balance the rim/tires, make sure you mount the tire to the rim first. I don't know if you were planning on balancing just the rim or just the tires, balance them together as a set. I'm only saying this because you asked ''Now how do I balance the tires.'', which lead me to believe you wanted to balance them separately....(which I guess might work.....? but would be harder overall I think?)
