Smart-Fly (Quest Engineering) Support Forum Support forum for all Smart-Fly products. Equalizers, Batshare, Ignition Cutoff, Regulators.
power expander question
Old 12-07-2005 | 03:59 PM
Default power expander question
i think i have already answered my own question, but here it goes. i want to see if i can use 2 li-ion packs with regulators with the power expander. by what i can tell i just have to by deans connectors to make this work. i can put each battery on a separate power terminal on the one end of the expander. has this been done? and are there any problems doing this? thanks for the info. toby....
Old 12-07-2005 | 04:12 PM
Default RE: power expander question
Hi Toby,
You can do this. The problem you are probably going to experience is that one battey is going to go down much faster than the other because regulators whose outputs are tied together do not play well together. One regulator is going to try and hog the duties, running its battery down faster. There is not way around this. Sometimes you get a balance where the difference is not too bad and some people live with this.
Old 12-07-2005 | 06:01 PM
rm's Avatar
rm
My Feedback: (27)
What about using the turbo reg. I thought I read somewhere that the draw between the two packs would be equalized?
Old 12-07-2005 | 06:04 PM
Hi Toby,
Yes, you can use the TurboReg and get equal pack draw. I guess I misunderstood your question.
