Gas to electric conversion
Hi all,
I have a 40" deep vee hull that had a Zenoha gas engine in it . At this point the engine and all hardware were sold and now I am in the process of converting to electric. I could use some help with motor size and ECS and hardware as everything will be new in this hull. I could use some help with selecting a motor, ecs and somegood hardware for the conversion as I am familar with lipos and and thier usesI have no idea how to select a motor for this application as well as what hardware should be used. Thanks guys for any imput on this project and lets build a fast electric boat.
MO
My conversion experience is limited but I have found reliable information here,,,
http://www.offshoreelectrics.com/conversion.htm and,
http://www.offshoreelectrics.com/propeller-chart.php
Bear i mind you did not specify if this was a sport or race project. Knowing your goals will help others better help with this project. I'm in fwiw. madgadget[8D]
This project will lend itself to sport, afterI familliarise myself with the whole electric aspect I might go with a cat hull ,who knows. Thanks for the links as I have much to learn.</p>
ORIGINAL: madgadget
