Go Back  RCU Forums > RC Boats > Speed - Electric
prop PRB4019 >
prop PRB4019
Speed - Electric For all your electric boating needs.
prop PRB4019
Old 02-19-2014 | 10:32 PM
Default prop PRB4019
I havent seen any one talk about this prop what would it compare to in name brand prop
Old 02-23-2014 | 01:42 AM
siberianhusky's Avatar
Pretty sure it's a Prather s215 or a very close copy of it if PB isn't rebranding.
Old 02-27-2014 | 05:43 PM
thanks is that un upgrade compared to the mg stock prop
Old 02-28-2014 | 05:08 AM
I think it is the same pitch and diameter but anytime you replace a plastic prop with a metal prop you will see an increase in performance due to less blade flex.
An Octura M445 is a popular upgrade but watch the temperature for the first few runs, if the boat isn't set up very well this prop can overheat things.
All props need to be sharpened and balanced before use unless you pay for one already done, there are a few people around who offer this service.
Be careful when working on props, if they are brass coloured it means they are a copper beryllium mix, the Br is VERY dangerous to you health, you do not want to inhale the dust. Once it's in your lungs it is not coming out!
http://www.chronicberylliumdisease.com/
I wear a respirator with a P100 filter and do all my prop work over a tub of water keeping everything wet, I personally will not use power tools to work props as it is almost impossible to control the dust.
