Kid bought a Proboat Blackjack. Got engine soaked.
So now it just beeps every few seconds and doesn't pair with the remote control. Are the engines allowed to get wet? He was throwing it around the pool. I'm guessing I have to WD40 it and let it dry out. Any and all help is appreciated since I know nothing about this. Thanks!
That sounds like either the speed control or the receiver, depending on it's drive system. You said the engine got soaked, so is this boat powered by nitro fuel, gas/oil or batteries?
Okay, that makes things a little more clear. Now I have a couple more questions for you so we can narrow this down a bit more:
1) Does the rudder work when you try to turn it with the transmitter?
2) Have you tried swapping the speed controller and rudder servo connectors on the receiver?
3) Have you tried to spin the prop shaft by hand(with the batteries not installed for safety)
These questions will harrow down where we need to look next:
- If the rudder doesn't turn, that says it's a receiver issue and you will need to try to rebind the receiver to the transmitter. This should be explained in the instruction book(s) that came with the boat. If it won't rebind, you may need to replace the receiver.
- If the rudder does turn, swapping the connectors will verify both channels work in the radio system and will rule out a radio problem and will tell us it's a speed controller or motor issue.
- Question 3 is to verify the motor and bearings are still in good shape. If the shaft spins easily, resetting or replacing the speed controller should take care of the problem if the radio is working properly. If you feel drag, that means either the drive shaft needs to be greased or the motor has corrosion building up inside. Removing and greasing the drive shaft would be advisable anyway as it's part of the basic maintenance required by R/C boats. I personally use a lithium based white grease on my boat's drive shaft
The rudder doesn't work with the controller. we also tried greasing the shaft but the shaft won't come out and even the guy at the RC shop said that it's stuck. I'll look into the other items and report back. It's a brand new boat and it's only been used in a pool very briefly.
Okay, that means the receiver got soaked. I would go through the instruction book(s) and see if there is a way to rebind the receiver to the transmitter. If not, you may have to replace it.
As far as the prop, are you saying you couldn't physically turn the prop shaft by hand or were you trying to turn it by using the controller? Just want to make sure we're on the same page on this one.
Something that would help is pictures of the motor shaft set up and the strut at the rear of the boat. Being able to see them might help me see why the shaft won't come out
You hit 10 with your last post. Your post count is under your join date in the box our screen name is posted in. As of right now, this will be my 8812th post over a period of 16 years
