Go Back  RCU Forums > RC Boats > Speed - Electric
 ESC Temp? >
ESC Temp?
Speed - Electric For all your electric boating needs.
ESC Temp?
Old 06-13-2004 | 11:26 AM
Red Rocket's Avatar
Default ESC Temp?
As my recent posts may portray, I am prone to ruining innocent esc's very easily. With that I have a new question,
What is a normal temperature range of an esc (on average) I have a temp gun, and it might be wise for me to moniter the temperature of my esc before I blow another. So like 50-120 degrees? Something like that?
Old 06-14-2004 | 07:29 AM
Default RE: ESC Temp?
Red Rocket,
I'm also monitoring the temp on my ESC with a temp gun.
At one point while running my boat to determine my ESC's thermal protection limit (cut -off),I got a temp reading of 110.4 degrees Celcius. I determined this as the "cut-off" temp as my boat stopped just a few feet away from me. I managed to pull the boat next to me,(boat still in the water) took the upper hull cover off & got the temp reading.The ESC I'm using has thermal protection.
Here's some info I found while researching a possible replacement power transistor for my ESC. Maximum operating temp on average before they burn out is 150 degrees Celsius.
If you have a background in electronics what would likely to burn out first in an ESC are those smaller transistors & those tiny resistors.
GulfstreamI
Old 06-14-2004 | 09:43 AM
Red Rocket's Avatar
Ok, ill check mine in celsius today, thanks for the info!
