NQD Hydro
RE: NQD Hydro
They are in series
6 cells on the 9,6V sp 700 hardly turns the motor.
I think better batts. wil help some
The prop is only about 8mm (0,31" ) from the bottom of the hull. I was scared it would cavitate agin like the other motor.
I found a picture of the Graupner Taifun which uses the same prop and shaft, and eyerballed it form the pic
Thanks for the tips. Still got the filling/painting to do at least.....
#32
RE: NQD Hydro
generally with a hydro, the prop will cavitate at first quite a bit before biting and jumping up out of the water
http://www.drcwebservices.com/ffe/hardware.htm
have a look at the hydro hardware here, will give you an idea of what the strut angle is and you can move the prop out from the back of the boat so it wont touch on the transom, also have a bit of a read on Surface Drives.... it will help you understand how they work which also helps in the setup, the basic principle is only one blade of the prop is in the water at once, which allows for a much larger, higher RPM prop, with reduced drag because none of the hardware hangs down below the boat causing drag
#33
RE: NQD Hydro
Im looking forward to seeing you Hydro being built.....and your friends.
When do you think yours will be ready ?
With the other motor, I applied throttle slowly, and it began to pick up a little speed, but then suddanly, you could hear the water cavitate, and it almost came to a dead stop in the water.
#34
RE: NQD Hydro
#37
NC
RE: NQD Hydro
It looks like it's running pretty good! I bet it's a lot more fun now than before.
If you want some more speed out of it, try stepping up the prop to a 42mm and see how she runs. That 700 can handle a 42 no problem.
#38
RE: NQD Hydro
Its WAY more fun than stock.......stock was just walking pace.
The temp. of the 700 is hot with no cooling at the moment, but it can certinly take more abuse.
Maybe I should find another motor mount that would alow a cooling coil around the motor.....its not nescesary as it is now.
I think ill make a duct from the huge air intake, and lead it down to the motor. That should help a little too
Got to get some more props next week.
#39
RE: NQD Hydro
here is the progress i have made, i hope to have it ready to run tonight
http://noonhost.com/mmpbc-about2.html
#41
CA
RE: NQD Hydro
Hi Sonnich,
Here's some pix of the scoop & cooling duct I put on my Twinstorm. These really help & it's a natural concept to take advantage of all that cool air passing over the boat !
Tony
ps; hope my photo upload worked
Tony
#43
RE: NQD Hydro
Hi Sonnich
first test wasnt very good, pushed a lot of water and didnt get onto plane, i was going to try an 8 cell pack but the receiver got wet so thats on hold for now although i dont think i will bother with the 540 anymore i will just put the 700 neo 9.6 in tonight and 12 cells will also be going in
Matt
Matt
#44
RE: NQD Hydro
Sorry to hear that.........
I have been thinking a little about mine, and what everybodey has mentioned.......
My CG is too far back, and I cant realt see how I could move it further forward. Also, I have to raise the prop a bit, and I think ill try that next. But there may be no point in doing that, if the CG isn`t correct []
#46
RE: NQD Hydro
ok, I can solve the CG issue a little easier........if I can do this:
I can move the engine and batteries forward about an inch or 3 cm, but because the prop shaft isn`t longer, the prop would also be moved 3cm further under the boat towards the front.
Is this a bad location for the propellor?
Will this effekt performance ?
I can also move the engine 3 cm`s back, and place the batteries infront of the motor.
This would make the prop stick out about 3 cm`s behind the boat, and the steering fin would have to be moved to one of the sides.
What do you think about these idea`s ?
#47
RE: NQD Hydro
ok.....now in the mix of plan E
One cool thing about buying a crappy bout, is you learn a heck of a lot rectifying the problems
So far, thanks for all the advise...I still hope to improve this boat.
I have moved the batteries into the nose section, and the motor aft. I have also raised the propshaft.....letts see how this works :-)
CG is MUCH better now than before.
#49
RE: NQD Hydro
Hi Sonnich well its been a lot of trial an error but i finally got mine to plane, one battery in the nose, and one beside the engine, i have my prop angle completely flat now, and also a ride plate on stuffing tube and i have modified the rear ride surfaces - ill post up pictures when i get home from work. My boat will not get onto a plane by itself and i have to throw launch it at the moment, then it actually quite fast!! ... because of your prop angle you have plenty of lift to get the rear out of the water, but it will cost you top speed. mine i am relying on the air and hydro lift from the hull to get the boat up out of the water
the rear wings are what is keeping the back of the boat under from breaking out onto a plane, thus i am going to chop the buggers off tonight, test run in the morning.
Matt
Matt
#50
RE: NQD Hydro
Looking forward to the pictues Matt.
I tried my new setup today. Im not too pleased with it.
I think it is working as it should.
The prop cavitates in the beginning, but when you advance the trhottle slowly, it comes up to speed, and planes. But as it is more nose heavy now, I can see the front pontoons are deeper in the water now, and creating more drag.
I can hear that the engine has alot more rpm when planing now, but I think it needs some more water to make this barge go
It is only slightly faster that the previos setup when the batt packs are fully charged.
When the peak charge has ben used in the packs, the boat slows a bit, and drag from the front realy slows it down alot.
I dont know what to try now......I think ill go back to the previos setup as the boat performs smoother through the whole battery pack span.
Also, because of the offset rudder, it now veers to the right the faster it goes, requireing trim.
