Go Back  RCU Forums > RC Boats > Speed - Electric
 esc question >
esc question
Speed - Electric For all your electric boating needs.
esc question
Old 08-15-2005 | 03:16 PM
rcmaster123's Avatar
Default esc question
would this esc [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGFN5&P=7]http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGFN5&P=7[/link] work with the graupner 700bb turbo??
Old 08-15-2005 | 03:59 PM
Default RE: esc question
Hi,
In principle yes, as a 700 on 12 cells draws an average of 25 Ah on a 8 minute run.
Getting out of the hole requires a much higher current (up to twice as much, depending on the prop) and that's where you might run into trouble, when the (thermal) overload protection kicks in.(see specs)
Having said that, I've run a 12 cell setup with a 700 motor, 45mm K-series Graupner prop for years on a Jeti 350 ESC(35 Ah continuous), in competition without any problems, but the occasional thermal shutdown when I had to get on the plane again after a flip.
I solved that issue by watercooling the ESC with a flat square piece of brass tubing, pushed under the shrinktube, over the heatsink where the fets are located.
Never had any problems.
Regards, Jan.
Old 08-15-2005 | 04:07 PM
so it would work if i watercooled it? coause thats what im planning to do
Old 08-15-2005 | 05:52 PM
whats Ah mean, amps?
Old 08-15-2005 | 10:51 PM
ampere hours. 25Ah means it can provide 25amps for an hour (usually applies to batteries). im not sure why he said Ah, maybe it was just a typo?
Old 08-16-2005 | 06:13 AM
Yes it should work fine, it looks to be exactly like the Castle creations ESC that I have. I have heard the 700 motors only draw 25-35amps for average running.
Old 08-16-2005 | 07:47 AM
ORIGINAL: kevinb456
Hi Kevin,
No it's not a typo, if the batteries would provide unlimited juice, the motor would draw an average of 25 Amp per hour.
Regards, Jan.
Old 08-16-2005 | 09:22 AM
but why do you say "per hour"
Ah is a measure of capacity - energy stored. motors are rated using amps which is a measure or required power. you said 25 amps per hour as if 1/5 of an hour would require 5 amps, and 2 hours would require 50 amps. the motor would require 25 amps no matter how many hours you run it for.
maybe its just the words you used, if english isnt your first language then probably just a mis-understanding.
Old 08-16-2005 | 03:08 PM
Hi Kevin,
You're right, and right again; English is not my native language, and I did mess up on my terminology, sorry.
Regards, Jan.
Old 08-19-2005 | 02:57 AM
Banned
lol
