Go Back  RCU Forums > RC Boats > Speed - Electric
 Atlantio 059 >
Atlantio 059
Speed - Electric For all your electric boating needs.
Atlantio 059
Old 02-07-2006 | 03:08 PM
Default Atlantio 059
I have two Atlantio 059s. One day, i took them out to a lake and inadvertently crashed them against some rocks. The hulls on both are fine, but both propellors are damaged. Does anybody know where I can get new propellors and how to make sure they are the proper size? Also, my little cousin got a hold of the antenna on one of the transmitters and broke it. It is the type of antenna that you can screw off. Anyone know where I can get a new antenna as well?
Thanks alot.
Old 02-07-2006 | 03:54 PM
tsherm31's Avatar
Default RE: Atlantio 059
The problem is that your boat is only 39.99 on e*****c.com so finding propellers that don't cost more than your boat could be a problem, if you can measure the diameter than they sell cheap props for like the traxxas villain, which comes in sets of two, it might just fit!? also antennas that screw in are all the same size, well not all of them...who makes your controller? Any LHS will have the antenna for you.
Old 02-07-2006 | 04:04 PM
tsherm31's Avatar
32mm in dia. with a pitch of about 1.6.
I found that for your props now see what you can do. drive safe
Old 02-07-2006 | 09:09 PM
Thank you very much for the info. Do you have any idea which is a good online store for buying props? I was looking at some props in a store (i forgot the name) and they were about $1-$3 each. I just don't know if they'll fit my boat, since they diameter of the hole might be different.
Old 02-07-2006 | 09:11 PM
Or is 32 mm the diameter of the hole? I need to find out the diameter of the "threaded shaft". What do you think about these props?
http://www.hobby-lobby.com/grboatprop.htm
Old 05-04-2006 | 03:16 PM
?? Anyone??
Old 05-04-2006 | 07:16 PM
Banned
I assume by the Atlantio 059, you mean the NQD Atlantio??
I know some E-bay Retailers sell the Props as spares to suite the NQD High Wind and Turbojet.
These may fit??
Could you post a Piccy of the Damage prop???
Old 05-04-2006 | 11:43 PM
32mm is the diameter of the prop i supposed. graupner props are usually 4mm hole diameter.
Old 05-04-2006 | 11:56 PM
Banned
If it is an NQD Boat then the Prop is going to have to be an NQD.. Most likely the Grey colored Prop will be the one you need??
They are a Narrow Prop almost 36mm in Diametre and have a 2.5mm threaded Section with a 5mm prop holder slot..
