Super Tune Your Super Vee 27
#2252
AL
RE: Super Tune Your Super Vee 27
Hey, look at it this way....you broke 38. That's an achievement.
Try some 2 part mix foam for the hatch or the foam in a can.
#2253
NJ
Ryan softshorting is an internal short in the cell. I was set to buy about 350 bucks worth of packs a while back. I was advised by the vendors that they where not the cells to run for sport boating. Now when you are going to spend that kind of cash and the seller sends you in a diffrent direction...well comen sence should tell you why.
#2254
ON, CANADA
I just revived one of the cells in my transmitter pack. Zapped it with 2 12v PB's. It now holds a charge instead of reading 0.000v. I tried it on another pack and melted the cell.
Ryan
Ryan
#2255
OH
Yesterday I reseated my motor water jacket using a little vasoline jelly and pushed on the jacket from the inlet/outlet areas toward the bottom of the motor hoping to get a better seal. I use a squeeze bulb full of water to test the system under pressure. I was getting a leak underneath the jacket between the inlet/outlet. I also reinstalled the Traxxas pickup tube higher using silicone. The pickup tube came loose so I scruffed up the rear of the pickup tube and the location on the transom using a fiberglass scratch brush. I still get good water flow under all contitions. I have attached a picture of the stern. Today I ran through two sets of batteries and absolutely NO leaks. NaDa, Not one drop.
Time to get the Bushnell Doppler radar gun out.
Prop is the M-445.
Prop is the M-445.
#2258
AL
Nice rear......prop that is. X445?
Sometimes the stock water jacket can be a bit of a hastle. The can has to be clean. I just had to push on it with pressure around the can to make sure the veins/guides/channels inside are seated. Having the water pickup closer to the prop wash area might even be a good thing. But these things are so minute, it may not even matter. When you clock her, that'll be all you need.
#2260
NJ
The CF 45 Launches....Observe...Unless we are talkin about the same prop.....
[link=http://s42.photobucket.com/albums/e343/STOAK/?action=view¤t=SV27March3rd.flv]SV launch[/link]
#2264
NJ
I am on the water also tomorow. I will be running th SV and the Jack. I may have the Jack on 16 cells if the mail man hooks me up today. I reajusted my tabs on the SV to let it air out a tick...should be fun. I will be self filming..I hope to get some quality clips.
#2265
NJ
I saw the picture of the 445m...Definitly not the same prop...lol. Nice tabs....Mine are like 1/2 inch wider....Why??? cause I clicked the wrong box when ordering them from OSE....HAHAHAHAH. They still work fine...they where just a ***** to bolt on. The nutz fell right behind the stringers...Uggg
#2271
AL
The CF45 might launch slightly better compared to the M445 because the CF45 has the tongue part of the prop where as the M445 is detoungued. This enables the CF45 to bite much better at the lower rpm band, however, the M445 has about a 3-4mph top end gain.
That's what I'm talking about.
#2272
NJ
When I firts got into modern boats I was unimpressed with people talkin bout 2,3 and 4mph gains. Now that I have run my boats... I look @ it way diffrently.
#2273
OH
I don't care if the M445 is bigger, greater, prettier, faster, awsome out of the hole, top end dancer. Just don't call me a "Putz".
#2274
ON, CANADA
ORIGINAL: SouthJerseyFe
Kinda like this.
[img][/img]
Kinda like this.
[img][/img]
That is totally awesome! I love it! I would like to see some more pics. And what is the maximum size boat do you believe it could push?
Ryan
