century speed boat motor upgrade helppp !!
Hi All
firstly keep up the good work with the ideas and mods
ok ,,I have a century electric speed boat with stock twin 380's with a single 1700 mah 7.2volt battery see pic below ..any recommendations to upgradeing the the motors to ?? as I would like it to be faster with a good run time of about 20mins ..possible ?? any ideas welcome
thanks
thanks
FL
RE: century speed boat motor upgrade helppp !!
i would gto with twin 540 motors (you probably need to upgrade the esc too....try using the motors and esc setup like useed in the traxxxas villain.....does your boat use "vector steering"? if so, trash that....that steering system doesent work as well as the good ol fashoin rudder and strut combo..
go to www.offshoreelectrics.com they have the motors and esc for the traxxas villan (youll probably need to get new batts too) and also carry some rudders you can use...
if you just looking to upgrade the motors and nothin else, sorry to say, but the stock esc (if its anything similar to the one i had in a different boat, but with the same setup) wont even handle an upgraded battery, let alone higher powered motors...
could you get some pics ofthe inside of the boat? and some of the transom...i still dont know if this setup uses vector steering, so that would help...
I'm about 90% sure it does, the models of this boat I found with google all used vector steering. There's even a warning not to use it longer than 15 minutes at a time.
ON, CANADA
In order to do it right you would need to get rid of most of you components. You would need to install a new radio system, ESC, motors, rudder system.
Do you really want to bury this kind of money? A better route to take is buying a hobby grade boat with standard upgradeable electronics.
Ryan
Ryan
HI...Some picks soon ..it is vector thrust ,,but for the time being I was just looking at to hopup the motors maybe a couple of 400's
thanks
thanks
My Feedback: (31)
WV
no smoke but youll see a power increase due to the increased discharge capabilities of the battery.. some lesser packs just cant put out what the motors and esc's need to really give it the full potential 3300+ would be my recommendation
HI ...Thanks ..
Ok ..correct me if I'm wrong here , from what is said I understand that as long as you keep the voltage the same eg 7.2 volts the actual mah's can go up to what ever there maybe eg 3300 or more is this correct
please let me know if I', on the right track
thanks
thanks
My Feedback: (31)
WV
ya MAH = time nothing more.. BUT better cells = more power output capable.. in Amps so take that into account buy a GOOD quality pack with a good mah 3300+ id suggest GP cells or IB
HI..Thanks whats the full name of the brands ??
venom packs ok ??
or something even better ??
thanks
venom packs ok ??
thanks
My Feedback: (31)
WV
ya venom packs are fine
http://www2.towerhobbies.com/cgi-bin...?&I=LXJZD1&P=0 this pack uses IB brand cells and the price isnt bad
id personally choose it over the venom pack because i know its a more capable pack
FL
actually, you probably will see smoke, my nqd (has the same setup as yours) smoked w/ the origional battery, then i upgraded to a 3600mah vanom pack...it went a lot faster, but i could only run it for about a minute or so before i would need to bring it in and check for smoke...and it sure smoked....
I change the 380s to 400s with a xL-10marine esc and added a working rudder. slap on a 7 cell battery and not even my ep hammer could keep up.
HI...Thanks,,
Now where getting somewhere...
Ok I understand about the batteries..but a little behind with the brushless motors and the latest versions of the brushless esc's ..??
Brushless motors = Speed ??
Brushless motors = torque ??
electronic speed controllers = ??
