Discharging a battery
I just bought a DTX 4200 battery and a MCR 959 charger, my questian is do I need to discharge the battery and how would I do this. Thanks, Randy.
RE: Discharging a battery
HI Randy ..
First of all what type of electric do you have..some use the vehicle ( boat , car etc ) to run down the battery or something else that could flatten the battery
Noddywa
Noddywa
Oh PS depending on the battery make and brand etc.. once the vehicle has run the battery flat it's time to recharge ,,some chargers also have a discharger to cycle the batteries
noddywa
noddywa
You need to put an intial "form charge" on NiMh packs. To do this, you charge them at a 10/C charge rate ( .42 amps or .5 amp). This should also be done on a regular basis. I charge my NiMh packs at 10?c about once a month. I probably run 15 to 20 cycles through my packs in one month's time.
Additonally, store your NiMh packs with a full charge and repeak them when you get ready to run them.
Personally, I use 3.0 amps as a normal charge rate...
HI..how Could I miss this ??? have to remember this one for later ..I'm learning something all over again , a little differen't though
