Esc and transmiter problems
Im sure its because im a noob at this but how do i get the esc to reconise my controler (fubuta 2pl 2 channel) i did not even use the stock controler once, because ive heard such bad stuff. I bet theres a trick to geting it to beep but it evades me.
Btw this is for a SV27, brand new, on 3800 DTX's Also i changed the stock servo to and reciver
Thanks a bunch
Thanks a bunch
Ok have you capsized the boat,or have you ran it,because I have had the same problems,it is most likely that you will need to send the boat back or take it to your local hobby shop because I had the same problem...took it to my local hobby shop....guy looked at it knew what was wrong and that fixed it
any other information can you provide me?
Thanks alot!
-Dwight
Thanks alot!-Dwight
You need to turn you throttle trim well in to the negatives for the ESC on the SV to recognize your radio receiver. On my Futaba 3PM, I'm at -45+ trim.
Ryan
Ryan
Exactly Ryan,
If you would use Airtronics you would'nt have that problem. I hate Futaba for that issue. Sometimes I can't even find neutral with the sub trim way back on my 3PK , and I have to use my good ol' Airtronics M11 ( The M11 always works for me , best Rx ever made )
Na i have not even drove the boat yet. I cant even get it to beep when i plug the batterys in...does it have to reconise the transmiter before it will beep? The batterys are fine i know...there DTX's 3800's
