Go Back  RCU Forums > RC Boats > Speed - Electric
 6" MICRO HYDRO >
6" MICRO HYDRO
Speed - Electric For all your electric boating needs.
6" MICRO HYDRO
Old 08-18-2007 | 05:39 PM
Default 6" MICRO HYDRO
Hi all! After some looking around I decided to build a hydro. Not the usual run of the mill hydro. This one is 6" long! Made from 2mm Depron, .25 Durabatics and some cheap packaging foam(will change to EPP). Weighs in at 4grams without electronics.
This was just a test build. I will build another more precise.
Matt
Old 08-18-2007 | 06:32 PM
Default RE: 6" MICRO HYDRO
Wow... That is awsome... well not yet once It runs. What motor do you plan on puting on it? How will you water proof the electronics?
Anyways... looks cool!
Old 08-19-2007 | 02:22 PM
Where are you getting a prop?
Old 08-19-2007 | 06:03 PM
i havent been able to find a small prop anywhere.
Old 08-20-2007 | 07:08 AM
Woodmandan2's Avatar
if you cover that with really thin ply and then take it to your local vaccum former (Theres on in my school) you could make a pretty nice hull... I did this with a tunnel hull and it was not bad, untill it was stolen when i was driving it, these guys drove towards it on thier fishing boat and then took a net and took the darn thing. It only went 15 mph so a fishing boat could catch up to it in no time and get it....for that thing i actullay used zigzag parts and a really small prop i took off toys....
Dan
Old 08-20-2007 | 08:04 AM
ryan_t888's Avatar
That looks very good for only being 6" long. I'm interested in your choice of electronics as well.
Ryan
Old 08-20-2007 | 10:13 AM
ORIGINAL: Dan Collins
Dan
Those darned fisherman!!!! It probably didn't measure up to the size limit either!!! J/K That was a BUMMER!!!! Next time a full size boat gets near try a zigzag with you're boat....
Old 08-20-2007 | 11:50 AM
Wheelnut's Avatar
My Feedback: (81)
ORIGINAL: knotnuts
Dan
Yeh, or start bringing a pistol with you[sm=devious.gif]
Old 08-20-2007 | 11:59 AM
Yea that thing is awesome! I'm really interested in what electrics you'll figure out for it.. Maybe a feiago 6s? [&:]
Old 08-20-2007 | 12:19 PM
ryan_t888's Avatar
If it were me, I'd run a Speed 180 on a brushed air ESC of about 5A. I'd also use a micro receiver with a micro servo. For a prop I would cut down one of the 1" Dumas .049 to around 20mm and finally toss a 7.4v LiPo 300-640mAh to top it off. Even with a 180, space will be tight.
Ryan
Old 08-20-2007 | 02:39 PM
CadillacDTS2001's Avatar
go buy a losi micro T and use those electronics
Old 08-20-2007 | 04:40 PM
bzinfinity's Avatar
Ok, I know I've seen it somewhere, give me a minute to look around online.
I've owned a 6 inch boat before, and I know it came with a spare prop, the whole kits were like 29.00. I think they were made by Megatech or a knockoff similar to Megatech.
It was a little red speedboat with a rudder and everything, it would be a perfect set of electronics for you to begin with. Let me see if I can fint it again when I get off work.
Old 08-20-2007 | 10:37 PM
you could use a tail motor to a heli... 2-5amp esc...maybe one of those small blue arrow recievers that are dinky... 2s 300-420mah lipogood luck, i might make one of those but bigger just to see if i can do it, lol. after i finish my micro rigger
Old 08-21-2007 | 10:03 PM
Hi guys, Thanks for the great comments. This is just an experiment for my new productline I hope to release in a few months. I will have mostly 1/64 rc cars, but boats and planes are on the list too. I have a private elecs designer designing both IR and RF radio systems for the cars,boats and planes. The RXs will be no bigger that 1/2"x1/2" and weigh no more than 1 gram. Most likely the motors will be either 7mm corless motors or a N20 size. Powered with a 3.7v lipo. Testing hasnt begun, but will soon enough. I have alot of things being designed/built at 1 time trying to release all at one time. Combine that with time with my wife and kids= slow progress. I try to get into the shop everyday, but Im sure you guys know how it goes. I have also designed a Tunnel Hull, based off of some free plans on the web. I used the plans to get general proportions of the boat, but not at all an exact copy!
This one is about 5.5 inches long. Hows it look so far? Still need to do the outboard.
Matt
Old 08-22-2007 | 07:09 AM
Those are some preety sweet boats !!! what is the price of em gonna be if you sell em???
Dan
Old 08-22-2007 | 07:15 AM
ryan_t888's Avatar
Matt, the tunnel looks great. I'd like to see what you come up with for an outboard.
Ryan
Old 08-22-2007 | 10:05 AM
crazy maxx's Avatar
tunnel looks good idk if they make motors that small?!?!?
Old 08-22-2007 | 10:57 AM
ryan_t888's Avatar
They make motors very small. I believe the pager motors are around 4mmX8mm and weigh just over a gram. The micro airplane guys use anything from 4mm-12mm and N-20's as well.
Ryan
Old 08-22-2007 | 03:31 PM
I am one of those avid plane guys! Boat kits might be as cheap as 10-15.00. Depends on how I produce them.
Thanks for the comments guys,
Matt
Old 08-22-2007 | 03:42 PM
crazy maxx's Avatar
how fast?!?!?!?!?!
Old 08-22-2007 | 03:43 PM
crazy maxx's Avatar
and mabey ill buy one to tow behingd my x mod
Old 08-22-2007 | 04:08 PM
i think they go 0 mph right now to who ask how fast they went. (no motor)
and if you want i think you could push it to go 20 mph, 30 mphmax
Old 08-22-2007 | 06:35 PM
yeah. . ok . try like 10 mph MAX.
30 mph is so far fetch hand gliding to Pluto is more of a reality.
Old 08-23-2007 | 12:45 PM
ryan_t888's Avatar
15 dollars for a boat kit sounds excellent. What scares me is the price of a hobby grade micro radio system. $150+ easily.
I'm still wanting to see this micro outboard. Have you been able to get any of the boats wet yet?
Ryan
Old 08-23-2007 | 01:42 PM
crazy maxx's Avatar
ORIGINAL: ryan_t888
Ryan
ryan said it all
