PROJECT: Speed
first does anyone no the speed record for the 1/12 scale miss bud boats. i am trying to get it to go as fast as our family boat. anyway post your ideas and thoughts and i'll need the best systems ever.and the best help
If you need to ask about any of that, you're not going to be breaking any records. How many years of experience in R/C boats do you have?
Sport Hydro has hit upwards of at least 80mph.
Ryan
Ryan
well i have a lot of brains in rcs mostly monster truck and the stampede. but 2 weeks ago i wanted something eles and living in mn with 10,000 lakes i wantted to start boating. and now i am planing to buy my first boat , a miss bud. so i don't no alot about the hulls and props and stuff but got plenty when i comes to power systems. and radios. my idea is in rc trucks if you get a low kv motor, with high rpm limits, and alot of volts to get to that limets. and that means tons of touque. and you can gear up, or in this case have a wild picth.
Your gonna need alot of knowledge of Props, Blue Printed Hulls and Water Dynamics if your going to bust any speed records.
Boats are different to Monster trucks in the fact that it is not necessarily the RPM of the Motor that translates into speed..
ORIGINAL: KEPPY_gotpedes
People just don't walk in to a new part of the hobby and crush world records. It takes decades of experience to do so, experimenting with many prototypes.
Do you plan to build this 1/12 hull from scratch. Is it going to be fiberglass or wood?
Ryan
what kind of set are you going to use to break it
how many cells ?
just a FYI a 6 cell boat ( 7.2 volts) will do 93mph and pull in excess of 300 amps
and thats a hydro
just remember more volts doesn't equal more speed.
how many cells ?
and thats a hydro
i am buying a miss bud i said that in my first post didn't i
but first thing i can tell you is you need a new hull. next . . that comes later
Ryan
ok i don't no i think i am buying a nitro,26",miss bud, wood i think,and it is converted to electric it has the words miss bud on it so it is not a pro boat and those other brands, no clue??????
Just to let you know, record-setting of any kind with any boat is no easy task. If it were that simple, we'd all have our names in the record books.
Any boat going for a record has to have every piece on it modified for speed and light weight. I know of one guy that went as far as removing the mounting tabs off the servos just to help save 1/10 gram!
that the problem the pic are big and i mean big and i can't download them in the from there in. forget aboat the recordeds, i just need it to go as fast as our 1:1 scale 250hp v8 inborde.
and our boat toped out at 53 with 4 people in it, 48 tubing
and it is not proboat. it looks way different then proboat, this one is electric too.
