Speed - Electric For all your electric boating needs.
STV OPC
Old 09-03-2007 | 08:16 PM
Default RE: STV OPC
One word: Video.
...Please [8D]
Old 09-03-2007 | 08:36 PM
crazy maxx's Avatar
Default RE: STV OPC
do u have and adjustibval jack plate???
Old 09-04-2007 | 07:04 AM
CadillacDTS2001's Avatar
Default RE: STV OPC
yes i do. i have 1/2 inch above and below to drop.raise the prop and 15 deg. up and down angle on the prop as well.
Old 09-04-2007 | 07:41 AM
crazy maxx's Avatar
Default RE: STV OPC
so try dropping the jack plate all the way down and trimming the motor up about 5 deg
Old 09-04-2007 | 01:14 PM
Default RE: STV OPC
ORIGINAL: crazy maxx
that will flip it. I don't want that.
the only thing is to make the boat run wet
Old 09-04-2007 | 01:54 PM
  #31
SV27dayton's Avatar
Default RE: STV OPC
Where's your power coming from Taylor? Less than what I thought if I remember.
Old 09-04-2007 | 01:57 PM
  #32
crazy maxx's Avatar
Default RE: STV OPC
ORIGINAL: Taylor Shaw
well mabey run the motor straightwith the jack palkte all the way down
Old 09-04-2007 | 01:59 PM
  #33
Default RE: STV OPC
well i am going to run the jack plate up high and the angle down. its the only way.
the power is a mega 22/20/1 with 6 IB4200's
it is a 5500 KV motor on a N2 setup
and its a 33 inch boat ( hehe!!) talk about knowing your setup
Old 09-04-2007 | 02:03 PM
  #34
crazy maxx's Avatar
Default RE: STV OPC
try it. if it works thats great...
but ustill need to get some video.action shots of this thing
Old 09-04-2007 | 02:06 PM
  #35
Default RE: STV OPC
i'm only one person. so its usually hard. but i will try some time.
Old 09-04-2007 | 02:11 PM
  #36
crazy maxx's Avatar
Default RE: STV OPC
cool
Old 09-04-2007 | 02:27 PM
  #37
Default RE: STV OPC
maybe i will get some guys at our club to do it one time.
well i just bought a Lehner4200 KV motor so it will run a smaller prop and have less RPM. this means with the smaller prop i can let it run wet and lose yet still be close to the water not to flip it.
should work. but what to do with this motor ?
Old 09-04-2007 | 02:50 PM
  #38
SV27dayton's Avatar
Default RE: STV OPC
That's amazing that you can make a 33" boat run that loose with 6 cells. Hats off. I really like it. You need to bribe the neighbor kid or something so you can get a vid. (I'm talking, my own kids don't want to do it unless they get to drive (and the don't).[:-]
Old 09-05-2007 | 08:49 PM
  #39
ryan_t888's Avatar
Default RE: STV OPC
Nice. That doesn't look like a 33" hull or are you referring to over all length including the K&B lower?
What is your prop height in relation of prop center line vs bottom of outer sponsons?
Where's the video so I can be the judge of speed? [X(] haha
Ryan
Old 09-06-2007 | 06:46 AM
  #40
Default RE: STV OPC
you cant judge speed. its to fast for a video. lol
my prop height is the same as the sponson depth.
the hull length it like 27 inches and to the prop its 33.
