Go Back  RCU Forums > RC Boats > Speed - Electric
 propchoise >
propchoise
Speed - Electric For all your electric boating needs.
propchoise
Old 10-06-2007 | 09:33 AM
joccee's Avatar
Default propchoise
im getting pretty long runtimes with the mogli. I havn't checked but it feels like 8 minutes maybe. And on 5000mah thats about 40A. Im running a x637, feigao 9L and 3s2p lipo. esc is cool lipos and motor around 90F exept for the shaft on the motor wich sometimes can be really warm. I was thinking about changing prop to a x640 or a prather 215. would it work with my setup or will I burn everything??
I think it shouldn't work but at the same time I think I should be pulling a lot more amps on my current setup.
What do you guys think??
Old 10-06-2007 | 10:59 AM
BB Modss's Avatar
Default RE: propchoise
Try a 215, check temps often!
Old 10-07-2007 | 03:29 PM
joccee's Avatar
will do that.
do the prather props need balancing and sharpening??
Old 10-07-2007 | 03:41 PM
CadillacDTS2001's Avatar
Yes. i believe they do
Old 10-07-2007 | 05:16 PM
ORIGINAL: joccee
will do that.
The prather ones I got needed balancing
Old 10-08-2007 | 02:44 PM
joccee's Avatar
okay..thanks.
I decided to go with a graupner prop wich is closer jump from the 637 I have now. the graupner prop is 40mm dia and 59mm pitch - this is just an icrease of the diameter(637 is 37x59.2). will this give more speed or will it just accelerate faster?
