Good motor for SV 27?
VA
RE: Good motor for SV 27?
Okay... Whatever you say man.
The physics of buoyancy and displacement still apply. That puny piece of spray foam in the bow (ALONE) is not enough to keep the boat afloat when full of water.
To tell someone...
Is just BAD ADVICE.
So let's keep it simple... You say "these boats do not sink"
Fill it with water, and see if it does? If it floats full of water, I'll stand corrected.
To tell someone...
ORIGINAL: ryan_t888
By the way, these boats do not sink
Ryan
Ryan
FL
Ive had both happen... Ive had enough air in mine to the point where theres only a inch of the nose out of the water and theres been other times that air has gotten out and just sunk. Next time I have everything out of my boat ill experiment with it.
ON, CANADA
How is that even advice I've given. One said his boat sank. I told him they don't, they have foam that is installed at the factory. He replied stating, he doesn't even have foam in his boat. End of discussion.
Grim himself said these boats DO not sink, they have foam in them. But what do I know, I haven't physically filled up mine with water and tried to sink it to the bottom of my lake?
Ryan
Ryan
VA
In your own words...
Emphasis on the last sentence
ORIGINAL: ryan_t888
All boat must have foam inserts somewhere in the hull whether it is electric or nitro. The electric sv I have here does have a decent amount of foam installed in the front. If yours was nearly sinking because you didn't tape your hatch shut add more foam immediately. Don't rely on 1 method of safety.
Ryan
Ryan
ON, CANADA
Go to the SV thread and browse the photos. You will notice no photos in there with any other form of extra floatation. First form of safety is hatch tape. USE it! If that fails the foam in the hull will save you as it has done to me and several others.
My point was I never said to anybody in this thread, do not place floatation in to your hull because it has enough. This seems to be what you are trying to tell me, as if I'm telling people "bad avdice."
Fact is, you must of have missed part of this thread. The boat alrady sank, now we need to figure out why? Looks like we have a few posts back.
I find this quite interesting
Post 2426 in Super Tune Your SuperVee Thread
Ryan
ORIGINAL: ryan_t888
These boats come stock with a big chunk of foam in the front. They don't sink.
Ryan
Ryan
ORIGINAL: ddmracing05
mine is freaking emptey! ****?
ORIGINAL: ryan_t888
That's unusual, I've never heard of that before.
Ryan
Ryan
ORIGINAL: Grimracer
The boats have foam in them.. they dont sink................
ROCK ON
Grim
ROCK ON
Grim
Ryan
#32
QC, CANADA
#34
VA
You are obviously under the false pretense that a tiny piece of spray foam is saving your boat from sinking when in actuality, it's the air pocket in the bow. I said "prove" to me that it's the foam and NOT the air. eliminate the air (flood your hull) then see if that crappy piece of spray foam will save you like you think. You'll be surprised what happens when you remove the air.
#35
VA
ORIGINAL: Peace_mit
it can float very good full of water ............
http://www.youtube.com/watch?v=MZWx0X94s60
#36
Anyone got a good Atermarket motor link for my SV27...
#40
WA
ORIGINAL: dirtysouth31
..the ammo motor is a better motor period..
one thing I like about the Ammo compared to the stock motor is that it isn't coggy - it spins free and smooth like a Feigao. This is helpful when you have to cut throttle instantly (i.e. when a boat flips in your path), as the stock motor freezes the prop and can cause your boat to roll over when slowing.
I run a barracuda 125 ESC with the Ammo.
#42
FL
http://finedesignrc.com/motorsnemesisblue.asp
I was Refered to those a few times by some friends. Supposely those have better ball bearings and what not in them and just "better quality". Havnt heard of them before though.
#43
WA
