Go Back  RCU Forums > RC Boats > Speed - Electric
 Min-Wax Polyurethane? >
Speed - Electric For all your electric boating needs.
View Poll Results: A poll
Yes to inside
0
0%
Yes to both inside and out
75.00%
dont use is at all
25.00%
Voters: 4. You may not vote on this poll
Old 03-24-2008 | 03:22 PM
Default Min-Wax Polyurethane?
I use epoxy to coat my hulls, some people use laquer, some use polyester resin. My question is can i use [link=https://www.hardwareworld.com/Pt-Polyurethane-Gloss-pYB7M4P.aspx]this[/link]to seal the inside of my hull. What about the outside?
Old 03-24-2008 | 04:04 PM
Default RE: Min-Wax Polyurethane?
Do you guys know?
Old 03-24-2008 | 04:17 PM
CadillacDTS2001's Avatar
I use WEST system and MAS for everything
Old 03-24-2008 | 04:44 PM
Ok well i am asking if its alrite to use this. Not what you use. Not to be rude, just saying.
Old 03-24-2008 | 05:05 PM
SV27dayton's Avatar
Not sure what either of those are.
Old 03-24-2008 | 05:09 PM
epoxy
Old 03-24-2008 | 05:47 PM
Silent-AV8R's Avatar
Yes, polyurethane will seal wood just fine. I've even used it in hulls in spray form to reach places I could not otherwise reach (in a hydro hull). You will want to put several coats (at least 3) to make sure. It is chemical resistant as well. It does not add any strength as epoxy will, but it does seal wood. On a wood hull it can also lay down a very nice finish that can be buffed to a very high gloss if desired.
Old 03-25-2008 | 12:59 PM
racer504's Avatar
I use Minwax Helmsman Spar Urethane (satin) on all my wood boats. I paint other products over it as clear wood finishes are not my thing. It's highly fuel proof and other products seem to adhere to it without problems. You can add micro ballons to it to get it to fill better (1st coat). 3 coats are the minimum I would use. Wait 2-3 days between coats and sand with 400 after each coat. If you want it glossy, buy the gloss spar urethane but use the satin for the first coats.
