Electro Vee Mod
FL
Electro Vee Mod
I currently am running a stock Vee with a 550 motor and 3:1 gear drive with Jeti Navy speed control on 12 cells.The prop is 48mm-if I put in a 700 motor direct drive will the prop be too big?I'm still going to use the stock outdrive setup because I'm too cheap to spring for better hardware.
