Speed - Electric For all your electric boating needs.
Props
Old 04-07-2008 | 02:42 PM
Default Props
Does anyone know how to measure props? I have a proboat shockwave and a caterman i want to get an aftermarket prop to go on them. Help please
the cat is a 24 inch 700 turbo 8.4 v running on a 10 cell. The shockwave is a stock 26
Old 04-07-2008 | 02:55 PM
SV27dayton's Avatar
Default RE: Props
I'm sure that someone can chime in and tell you what props work best on the shockwave. I can't- no experience with the boat. Is it stock. As for the cat: can you give the legnth, motor, and power you are running, also include weather it's direct drive or a gearbox. If it's a known brand and is stock just say what it is and somone will know what it needs.
Old 04-07-2008 | 09:34 PM
Russ Williamson's Avatar
Default RE: Props
This might help; after going to this link check out the prop chart and the sharpening and balancing instructions. You will need to get some tubing to space out the prop to the prop shaft because of the boats odd prop shaft size.
Any questions, let us know - thanks!
http://www.aquacraftmodels.com/acces...ropellers.html
Rw
ORIGINAL: ddawn123
