SV27 receiver pack
Could I get some suggestions on receiver packs for my SV27. I read that you should use one when using 7-cells. Also, is the drive shaft of the Aquacraft Hammer 1/16"? Thanks
But why does they write these stories like this one:
http://www.rcuniverse.com/forum/m_7464991/tm.htm
The receiver pack powers your receiver and steering servo. The BEC function of your ESC steps the voltage from your main batteries down to 6V and uses this to power the receiver and steering servo. With input voltages too large (more than 12 cells) this functionality will not work properly which is why you need to use a receiver pack. Also you are more prone to radio glitches using the BEC.
Hope this helps.
Greg
Hope this helps.
Greg
I have the same problem as the story finvee27 referenced. Works fine on 12 cells but on 14 cells it has a mind of its own. So if a 6v pack is all I need, who makes some good ones? Maxamps?. And is 3mm the same as 1/8" when referring to the hammer drive shaft?
You don't need a 6v pack. A 4 cell 4.8v pack will work great.
http://www3.towerhobbies.com/cgi-bin...&I=LXNRH6&P=ML
http://www3.towerhobbies.com/cgi-bin...?&I=LXPYL6&P=7
3mm is slightly smaller than 1/8"
Ryan
Ryan
that is a good question. In all the testing I have done (and there has been a TON) I have never needed a RX pack for the boat on 14cells. having said that.. I also have found that the addition of the extra voltage did not add anything to the "fun factor" of the boat. I run my SV on 12 cells and leave it at that.
IF you feel it is best to use a RX pack then by all means go ahead and get what you want. That works too.
ROCK ON
Grim
ROCK ON
Grim
ON, CANADA
Since I was quoted in this thread with my response to why BEC shouldn't be used with more than 12 cells I'll clarify. I was responding to a question someone asked about why he had been told (by someone else) he needed a receiver pack if using more than 12 cells. Of course this may vary somewhat from ESC to ESC but like Ryan said it is a general rule of thumb. I've never owned an SV27 nor have I ever used an SV27 ESC so I don't know if the BEC can handle 14 cells or not.
Greg
Greg
world of warcraft Powerleveling
. wowpower-leveling.com is an Expert Online
world of warcraft Power leveling
wow Powerleveling
Site, dedicated in providing customers with fun in the professional service of
wow Power leveling
. Excellent Service, Super wow power leveling.
MapleStory Mesos
Maple Story Mesos
MS Mesos
wow gold
Buy WOW Gold
WOW Poweleveling
WOW Powe leveling
wow Powerleveling
wow Power leveling
MapleStory Mesos
Maple Story Mesos
MS Mesos
wow gold
Buy WOW Gold
WOW Poweleveling
WOW Powe leveling
WA
ORIGINAL: lihong
wow Powerleveling
wow Power leveling
MapleStory Mesos
Maple Story Mesos
MS Mesos
wow gold
Buy WOW Gold
WOW Poweleveling
WOW Powe leveling
wow Powerleveling
wow Power leveling
MapleStory Mesos
Maple Story Mesos
MS Mesos
wow gold
Buy WOW Gold
WOW Poweleveling
WOW Powe leveling
Greg from Canada.. Are you making a statement with your bold print?...aha... no need to answer that question.. forget I asked......
Keep the faith man.. I jumped into say he did not.. it is what it is.. bottom line, for most of us its fun to work on, own, operate and buy cool things for the SV..
Keep boating
Grim
Keep boating
Grim
ON, CANADA
Keep boating
Grim
Keep boating
Grim
Greg
