NEED THE ELECTRIC GURU
FL
I have come across an extra supervee brushlessand an extra 11.1V 8000 Lipo battery. I have figured out the balance of one battery in the boat. Is it possible to run one battery on the stock motor and ESC or what will I need to do, to do this or is it possible? Just think it maybe a cool project seeing as I still have my boat to drive around and no money into any of the extra stuff so far.
ON, CANADA
RE: NEED THE ELECTRIC GURU
If you're using deans on the LiPo, all you need is a female deans connector with the posts soldered together. This can be placed on the other connector as 2 packs are used on the SV ESC. 11.1v and 8000mAh is going to give you longer runtimes at a cost of speed.
Ryan
Ryan
