Unofficial "NQD" Tear into Jetboat Thread
#1277
MT
RE: Unofficial
ORIGINAL: richdb77
Has anyone replaced the ''rubbery'' bush in the NQD drive with a bearing?
I am having a hard time finding a roller bearing with 2.3mm I.D.
You can see in the pic with them installed in the drives.
#1278
Location: Brandenberg, Germany. Formally East of England
RE: Unofficial
Maybe a silly question but bear with me.
I have a 35A water colled ESC and was planning on running a 11.1v 2200Mah lipo battery. However this has failed to show (dodgy fleabay seller) and its got me thinking that maybe 2200Mah is too high Amp wise for my ESC?
If so is 800Mah better (lower peak Amps) ?Whats the run time like on 800Mah?
Sorry if its very obvious.
#1279
RE: Unofficial
ORIGINAL: richdb77
If so is 800Mah better (lower peak Amps) ? Whats the run time like on 800Mah?
#1280
RE: Unofficial
ORIGINAL: ryanwilson277
ran mine and lose prime even at less then half throttle
#1281
RE: Unofficial
yep after you remove your motor try to move the shaft up and down side to side if there is any movement your probly sucking air and loseing prime that away . you need to put a 1/8 wall brass tubeing in to shim it back out . if its the stock drive .
#1282
RE: Unofficial
PM, you'd be better served with a Graupner mini in that boat, so you can obtain spare impellers. If it is a worn shaft area causing aeration (priming problems), you might try Grim Racer Speed Grease. It is thick, waterproof and will stay put. It should fix that if it's not crazy worn out. In fact, it is so viscous it will bog down a flex cable drive if you pack it in. Sdg
#1283
MD
RE: Unofficial
i think that might be the problem because after i run the boat i bring it in and slowly run it with the top off and water gets flung around off the coupler, just a little bit, so im gonna do what you said but i still dont understand how to do it. sorry lol
#1284
RE: Unofficial
I broke my impeller on the stock jet pump this weekend. Now I'm torn about what to do. There don't seem to be any really great options for finding a replacement impeller. Any advice on which of these is the best option?
1. Buy another NDQ and just tear the jet drive out of it.
2. Buy the small graupner jet pump and put it in (Costs more than a new boat with drive...)
3. Buy the 29mm graupner pump and go crazy with it.
4. Try to hack a graupner impeller into the nqd pump.
#3 sounds fun but I take the boat camping with me so I shoot for simple and reliable, which I suspect this beast would not be. It's also likely to be far more work. I like the idea of the bigger pump though because I'm hoping it will lose prime a lot less. My stock pump was practically useless on anything but calm water due to losing prime, and what's the point of a jet boat that can't do rapids?
Any Advice?
Any Advice?
#1285
RE: Unofficial
Cheapest fix is to buy another boat($43 [link=http://cgi.ebay.com/New-Remote-Control-Electric-Air-Jet-Racing-Boat-R-C-RTR-/250649602369?cmd=ViewItem&pt=Radio_Control_Vehicles&hash=item3a5be16941]delivered)[/link]. Then do a clean cut and remove of the hatch, remove the jet drive and then sell the hull on ebay to recover some cost.
Next would be to buy a Graupner mini impeller and a 2.3 to 3mm coupling. Then drill out the shaft hole and the rear bushing to 3mm. Be sure to lube before use. When that shaft hole wears out later, bush it with brass tubing.
I'm not a fan of turning down props for this job. Sdg
#1286
RE: Unofficial
buy a new boat and a 29mm graupner drive =)
also, do NOT run big batteries. Yes, the ESC could handle them, but both eTokyoPop and I burnt up a 2040 3200kv walkera motor in less than 1 run using the 3000mah 3s 20c batteries we had originally ordered. We think it was because of all the weight they carried, but arent sure.
#1287
RE: Unofficial
That wasn't the batterys' fault. The battery will give the motor just what it asks for. And it will ask for more when in a bind. When the Walkera motor is supplied with sufficient amps it can really haul, and will create a lot of heat because it is almost borderline on the power scale. So it's my guess that was because of improper cooling. Tubing won't cool the Walkera motor sufficiently, even with heatsink compound. You need to use a full length water jacket on that motor, and be sure there is adequate flow available (shooting out a little stream).
The smaller battery won't supply enough for it to reach that level, so no worries there except maybe puffing a low C (cheap) battery.
#1288
RE: Unofficial
yea, still no idea how electronics work lol
we have been looking for full-length water-jackets though, tough to come by. temped to talk around to some friends and get them custom-milled with a larger "reservoir" around the motor to hold water for a longer period of time..would seem more efficient to me
#1289
RE: Unofficial
If the motor is burning up from too much current, going to a smaller battery will just make the battery the weak link. The only way to properly fix a motor drawing too much current is to get a beefier motor, or smaller/less pitched prop, or give better cooling.
I've got my boat in pieces already, partially ready to be re-assembled. Hopefully it'll get the base coat of paint tonight so I can get it back together for the weekend!
#1290
RE: Unofficial
Guys,
can you just go over that sucking air thing again please?
do you mean that the plastic hole in the drive that the shaft goes through gets worn? but the 2.3mm shaft isnt that tight a fit, so how is it getting worn, and with the coupler and rubber bush fitted, where is the air coming from?
just curious about this, I have just removed the grate and stator guard mod, fitted 3 small carbon rods in the intake to act as garbage protectors. I was thinking the grate and stator protector plate where the cause of real bad loss of prime on the slightest of choppy water
#1291
RE: Unofficial
Yes, that is what Damfurst was talking about. The hole the shaft goes through wallows out after a while with high rpm's (stainless and plastic not being the same hardness). It will suck air thru this shaft bore when you lose prime and make it harder to pick up water. Early on (maybe what you're experiencing) you can fix it by lubing with a thick waterproof grease (like Grim Racer synthetic grease). That should stop it from sucking air until it throws and needs reapplication or until it wallows out further in which case try the above methods. A brass tubing liner will last longest and you can fit a replaceable Graupner impeller. The rubber seal is just to keep the grease in, not water and air out. You can get fancy and fit a means to lubricate (small tubing) the shaft more easily. Sdg
#1292
RE: Unofficial
What diameter tubing is anyone using for the liner? I can't find anything except 1/8" or 3/32" O.D. tubing, neither of which fit. The 1/8" fits over the shaft but has a bit of play, it is less than my pump has stock in the plastic though, so I'm tempted to just use it.
#1294
RE: Unofficial
^^ I'll have to drill out the intake to fit the tube, I just wanted to see if anyone found tubing that was a tighter fit. I'm definitely going to run brass all the way to the impeller to keep it from moving around .
#1296
RE: Unofficial
ORIGINAL: bustitup
anyone have one of these available
Turnigy 2836 Brushless EDF Motor 3200kv
#1297
My Feedback: (7)
RE: Unofficial
Ya those are on back order
ORIGINAL: sundogz
Heres the [link=http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=8138&Product_Name=Turnigy_2836_Brushless_EDF_Motor_3200 kv]link[/link]
ORIGINAL: bustitup
#1298
RE: Unofficial
Not that its a huge help because its out of stock too, but this is the one I ordered:
http://www.hobbycity.com/hobbycity/s...dProduct=11173
Same size and kv, should be a comparable replacement. It's a little down on wattage, and max voltage but will still be plenty powerful on 3s.
#1299
My Feedback: (7)
RE: Unofficial
yup I like that one too....i'm going to use this till those become available....i'm going to have to run it on the only 2s I own.........xps 2s 5000mah 30c...i figur the boat can use the extra weight...lol
http://cgi.ebay.com/KV-3700-Brushles...22980819534754
ORIGINAL: wparsons
