HK Small Bolt Hydro same as HOTR
#351
RE: HK Small Bolt Hydro same as HOTR
Chipped one blade off my 30mm plastic prop this afternoon at the pond.
Good thing I have a spare 30mm prop.
Still waiting for my Octura props. . . .
Here's a video my friend took on my 2nd run. . . .before my prop got clipped. Too many floating debris!
http://www.youtube.com/v/ItwGV2cywHM?fs=1&hl=en_US
#352
You guys might be interested in the 60A esc . . .
http://cgi.ebay.com/60A-Watercool-Wa...item45f630d7f3
#356
Here it is autumn but it feels like winter. It is very very cold (and early dark after noon) so after my work I am not able to run the bolt.
In the weekend I wasn't able to run it because it was raining all day long.
It is way too cold here, but every time I see it I want to run it so I guess I am going to run it soon
#357
Octura X430 & X432 props just arrived!
Have ordered the 60A esc from eBay.
Will be trying out the Outrunner 4200Kv next.
#360
In case any of you want to try out a 3 blade prop . . . I found one!
Venom 432/3 - nylon. Ordering one as soon as it's back in stock.
This isfor the Venom EKOStwin prop boat - picture below.
If you're ordering, make sure you get the "LEFT" prop pictured here.
UPDATE: Propswe can use . . . but I think that the 35mm props (in red) are too much . . .
These props are all for .125" or 3mm stub shafts. No shim needed.
All props indicated are metal unless stated.
Octura:
1.25 - (31.7mm dia. x 1.8 pitch)
1427 - (27mm x 1.4)
1630 - (30mm x 1.6)
1732 - (32mm x 1.7)
1735 - (35mm x 1.7)
1930 - (30mm x 1.9)
2132 - (32mm x 2.1)
2135 - (35mm x 2.1)
X427 - (27mm x 1.4)
X430 - (30mm x 1.4)
X431 - (31mm x 1.4) plastic
X432 - (32mm x 1.4)
X435 - (35mm x 1.4)
X632 - (32mm x 1.6)
Y531 - (31mm x 1.5) plastic
Y534 - (34mm x 1.5) plastic
Y535 - (35mm x 1.5)
P735 - (35mm x 1.7)
M435/3 - (35mm x 1.4) 3 blade
V935/3 - (35mm x 1.9) 3 blade
Venom:
3 blades (nylon, aluminum CNC andPro versions)
432/3 - (32mm dia. x 1.4 pitch)
http://www3.towerhobbies.com/cgi-bin...RCH=venom+ekos
Aquacraft:
for Hammer - EP - plastic prop
30mm dia. x 1.65 pitch
Comes ina pack of 2.
http://www3.towerhobbies.com/cgi-bin...&I=LXMNN0&P=ML
This is the prop I clipped and the one on my video. Runs good!
OSE:
32mm dia. x ??? pitch - metal
http://www.offshoreelectrics.com/pro...-80700&cat=123
Mini Cat:
plastic and stainless props
http://minicatracingusa.com/mparts.html
Let us know if you come across other props!
Octura:
1427 - (27mm x 1.4)
1630 - (30mm x 1.6)
1732 - (32mm x 1.7)
1735 - (35mm x 1.7)
1930 - (30mm x 1.9)
2132 - (32mm x 2.1)
2135 - (35mm x 2.1)
X427 - (27mm x 1.4)
X430 - (30mm x 1.4)
X432 - (32mm x 1.4)
X435 - (35mm x 1.4)
X632 - (32mm x 1.6)
Y535 - (35mm x 1.5)
P735 - (35mm x 1.7)
Venom:
Aquacraft:
OSE:
Mini Cat:
#361
ORIGINAL: carakter
Venom 432 prop = 32mm dia. x 1.4 pitch - 3mm shaft
It's fairly cheap at $3+ each.
Or you can try the CNC version - aluminum and Pro - if you've got the cash!
I will upload other props we can try with the Bolt . . .
Including 4mm props we can try if we use a prop shim. (4mm o.d. brass tube).
#362
would the pitch of this prop be to big for these boats. 37mm?
http://cgi.ebay.com.au/ws/eBayISAPI....=STRK:MEWAX:IT
only thing you would need this spacer.
#363
@wilsta67 - the Venom 32mm props are on backorder. Even at the Venom website . . .
check here:http://www.venom-group.com/itemdesc.asp?ic=1981]
As for the ebay prop you reffered to, if I am not mistaken, that's an Octura X437/3 - (37mm diameter, 3 blades).
If you're asking me, I wouldn't recommend it for the Bolt. I could be wrong.
I think that 35mm dia. is the biggest I would consider trying.If I do this, I wouldprobably change toa lower Kv motor than stock.
One way to find out is to actually test it in the Bolt. Care to try it?
Bear in mind that the bigger the prop, the higher Amp esc you will need . . and a torquier, lower Kv motor. . . . because . . .
Big props = huge ampdraws![
#364
those 3 blade props are in stock now have you had a chance to try them?
#365
Yup! Just ordered 2 pcs. and the hammer props from Tower.
My mom's coming over on the 23rd so she'll just handcarry it.
Will let you know how they perform.
#366
ORIGINAL: nickster46
To carakter: which 60A ESC have you received? Is it that cheap ESC from ebay , that become unavailable?
#367
@Yura - The esc is not here yet.Uusually takes 3 weeks- 1month to get here. []
I don't know if it's the same unitas nickster has but the price has gone up a bit.
I just checked Ebay I think Force-Control and Mikingstore (where I got mine) is one and the same.
#368
I received my ESC finally 1 week ago.
It was necessary to open a case for the transaction because the seller wasn't responding and the item wasn't arrived.
So at the very last moment the seller responded and I was promised to get a refund. I had the esc ordered again on ebay (I think it was a different seller) and I received this one very fast.
and also the other esc arrived.
#369
So yo have paid for one but get 2?
If so you should pay to seller you have asked for refund
Have you problems with 1st seller "force-control"?
Now 2 sellers available:
Price about $25
Can't choose which to order... ESC definitely the same. Difference is only in seller and seller's proposal to different countries (1st and 2nd links).
#370
OH
This is what I bought:
http://cgi.ebay.com/ETTI-45A-Water-c...item483812219d
#371
@Yura - I believe they're one and the same seller.
@nickster - I have bought a few items from ETTI. His items are a bit pricey but they're well made.
#374
ORIGINAL: carakter
This is for the Venom EKOS twin prop boat - picture below.
If you're ordering, make sure you get the ''LEFT'' prop pictured here.
The 'search this thread' feature isn't working for some reason. Can anybody tell me just what this stock esc is? (brand, Amps, Volts) and how to program it. It may not be worth using with a 32mm prop.
#375
The Force Control 60A ESC and the Venom 32mm props are here . . though I have been pretty occupied lately. This confirms my suspicion, Force Control and Mikingstore is one nd the same person. I must say that i did not expect it to be huge and heavy!
sundogz- I have not test fitted the Venom prop. It's just sittting in my drawer. I will have to check if they are loose fittingon the shaft, I'll get back to you this weekend.
Stock Small Bolt ESC specs: watercooled, 30A, 3S . . . though some have tried 4Swiththe stock 2604Kv motor.
Still have not gone to the nearby pond (pond in my video)as we're awaiting the release of our new permit from City Hall.
