Batteries C vs Sub C?
So if I can get them for about the same price, why not go with C size and more Amps? Are there any other differences other than the small difference on size?
I found C size batteries for like a dollar more for a set of 10 and 5000mAh vs Sub C at 3800mAh. Any thoughts on this? |
RE: Batteries C vs Sub C?
They are bigger and heavier
And in many cases they may not deliver the amount of current needed as their C ratings are usually quite low.
Ryan |
Hi
Anyone knows if is possible to run a 7.4V 4000mAH 10C lipo battery in the Pro Boat Blackjack brushless with stock Motor and Esc. Thanks. |
Refer to this answer
http://www.rcuniverse.com/forum/fb.asp?m=7993364 I believe the guy says no you can't. Ryan |
ORIGINAL: gilverado11 Hi Anyone knows if is possible to run a 7.4V 4000mAH 10C lipo battery in the Pro Boat Blackjack brushless with stock Motor and Esc. Thanks. |
ORIGINAL: CadillacETC2000 ORIGINAL: gilverado11 Hi Anyone knows if is possible to run a 7.4V 4000mAH 10C lipo battery in the Pro Boat Blackjack brushless with stock Motor and Esc. Thanks. |
| All times are GMT -8. The time now is 11:00 PM. |
