2 stroke oils
2 stroke oils
I'm curious what kind of 2 stroke oils are you all running in the zenoah 26? Besides what the dealer sells. Is XD-100 safe to run?
NB, CANADA
RE: 2 stroke oils
you may get a lot of opinions on that one but here is a few choices;
Morgan cool power blue synthetic,
Klotz Super TechniPlate,
Maxima 927,
Belray MC-1,
Castrol A747,
Honda HP2,
Amsoil Dominator,
Amsoil Saber pro,
Motul 800,
Royal purple TCW 111 racing,
quick silver premium,
RedLine Racing.
only to name a few.
approx 5oz to the gallon on a stock engine and
8 to 10 oz per gallon on a mod engine.
I run Dominator @ 16:1 (8oz per gallon), I may give the cool power blue a try.
Dan.
Maxima 927,
Belray MC-1,
Castrol A747,
Honda HP2,
Amsoil Dominator,
Amsoil Saber pro,
Motul 800,
RedLine Racing.
only to name a few.
Dan.
RE: 2 stroke oils
im running silkolene comp 2 premix oil.
mixed at 20;1. stripped an engine after using a couple of gallons of fuel, very clean inside and in top form.
regards
nigel
regards
nigel
NB, CANADA
RE: 2 stroke oils
ORIGINAL: Johnnysplits
I run Redline Racing synthetic mixed at 40:1 on coleman camp fuel
added to my list.
Dan.
RE: 2 stroke oils
Mercury Quicksilver SAE@ 8.5oz/gal with Sunoco 110 Leaded (simply cause its ethonal free). Been 75+ with cat..so doubt the high octane is killing power since its run the same on 87
RE: 2 stroke oils
ORIGINAL: MrMikeG
Castrol A747 synthetic mixed 20:1 with cheap gas, no ethenol.
??? You do know that the combustion engine was originally designed to run on ethanol don't you. Petrol didn't exist when Henry Ford first made the Model T. When the Americans Introduced probation he had to find another fuel source as ethanol is pure moonshine, hence why we have fossil fuels today.
I run BP Ultimate with full synth oil, 40/1 but I do use 98 octain with ethanol some times as do the whole field in the V8 Super Cars, They use a 98% mix with 2% petrol and the 2% petrol is only in it so people won't drink it. It is not a problem, It's more the crap that the rip off petrol stations over here add to it. "Ahhhh 1000 apologies", So I should bloody thing so .
I've used it in my Quads, Karts, Bikes and Cars with no Issues.
"Go Well, Go Shell" Says it all IMO .
RE: 2 stroke oils
ORIGINAL: Willow991
ORIGINAL: MrMikeG
Doesnt cause much of a problem in low RPM engines... but it causes fuel delivery problems when you are trying to turn 18000-19000+.
RE: 2 stroke oils
ORIGINAL: Fuel Crazy
the problem with ethonal is it attacks the rubber parts (diaphrams). I was going through a diaphram every weekend running unleaded w/ ''up to 10%'' ethonal. Since switching to ethonal free race gas, i have not had to change a diaphram in 3 months..and this is with engines turning upwards of 20,000rpm.
ORIGINAL: Willow991
''Go Well, Go Shell'' Says it all IMO .
ORIGINAL: MrMikeG
Well I don't know what's going on there. I won Australian Kart titles using ethanol fuel and Karting is very close racing.
Do you spray your boats with anything like CRC, RP7 or alike? That eats into rubber.
As I said our V8 Super car racing over here use it in every car, It's made from sugar pulp by CSR, I know the Bloke who is designing the new speck engines for the class and he gave me the Info I posted above. They wouldn't use it if it were no good, Ever heard of Bathurst ?
RE: 2 stroke oils
no i dont spray my boats with anything.. and it would not get into the carb where the diaphrams are anyway if i did. Plain and simple it attacks the rubber. Ethanol is also a polar solvent..so it absorbs moisture. Maybe you have different ethanol over there, vs the corn based ethanol here.
RE: 2 stroke oils
Thanks guys for all the information. Decided 2 go with quick silver premium. Its the only one i can get my hands on down here for the time being. Our gas down here is ethonol free so I think I'm safe.
GA
RE: 2 stroke oils
ORIGINAL: Cayrider24
RE: 2 stroke oils
Personally I love the smell of a caster oil-has that race smell that just does it for me. I run it in everything!!! Its not a cheap oil but thats a good thing!!!
NY
RE: 2 stroke oils
This year I'm going to try Klotz R 50 I did some research and like the numbers,
called the Tech dept. they said E10 pump gas would be fine to use
http://www.klotzlube.com/proddetail....04_Quart&cat=8
http://www.klotzlube.com/techsheet.a...8&submit2=View
RE: 2 stroke oils
ORIGINAL: idocdave09
