Bilge pump
The problem with autobailers (aptly named by some wags as autosinkers) is that they only work when the boat is moving and sometimes get debri stuck in them holding them open rendering them useless if you stall or stop moving. If you run a clutch and sit still , water will still come in stuffing tube and eventually sink boat if you don't move from time to time.
Check out what the guys with the battling warships use. some build what is known as a penny pump.As the name implies its built using a penny with impellers soldered onto it and put in a housing. driven with a small motor it will pump water with little weight penalty.
A windshield washer pump (or similar) would work ok though you would need a battery to power it. You could run a waterpump (same as everyone uses for clutched motors) though it will only pump water when the motor is running (uses motor pulse to drive pump). So far I have never had a problem with an autosinker/autobailer. There should never be debris in your boat (your carb will ingest it if there is).
I believe the Aeromarine, autobailers have a small screen on the end of them that is inside the hull. I use shortened, Octura, autobailers in 2 of my boats now. They have no screen in em to get clogged. I shorten them in a lathe, by 1/2". This way you only have about 1/16", sticking out of the rear of the transom, and about 1/16" on the inside. (with a press/fit) Enough to run a bead of epoxy on. (The one on the left is stock) Never had an issue yet!
I love em, their GREAT!
Brian
Brian
WOW!! I really like your boat!!
I like the closed top-deck. Which brings me to a burning question:
Is your engine water cooled? I think that is a pre-requisite for having a closed top-deck right?
Ken, My buddy has a 50" Bonzi "V" hull with an autobailer mounted to the left of the strut, way down low. It's been working good for him too. z00100, do you have a name? LOL YES, The engine is water cooled, and the pipe is too. Look again at the first pic. The water pickup is on the rudder. From there it go'es into the cooling ring on the engine, out to the cooling ring on the header, out to the cooling ring on the pipe, then exits on the left side of the hull thru thems 2 lil silver thingies I made.
(first pic) Brian
(first pic) Brian
Yes, there are bilge pumps specifically designed for model RC boats. These miniature pumps are used to remove water that accumulates inside the hull, helping to keep the boat afloat and operational. Typically powered by a small electric motor, they can be activated manually or automatically, depending on the model. Many hobbyists incorporate these pumps into their RC boats to enhance their performance and durability, especially in rough water conditions or when undertaking longer runs. It's a great way to ensure your boat stays dry and performs at its best!
