Rare Earth Magnets - Where to purchase
IA
On my last post it was mentioned to use magnets for the hatch - (Rare Earth Magnets)
Can anyone ponit me to a link for purchase or post pics on the install
Thanks for help
coop
Thanks for help
coop
My Feedback: (12)
SC
RE: Rare Earth Magnets - Where to purchase
Here's a link to some [link=http://www.radioshack.com/product/index.jsp?productId=2102642&cp=&origkw=rare+earth&kw=rare+earth&parentPage=search]Radio Shack rare earth magnets.[/link] I don't know if these are what people were using or not.
Edit: on a whim I went to [link=http://www.mcmaster.com/]McMaster-Carr[/link] and sure enough, they have them in a variety of sizes. Just search on rare earth.
My Feedback: (48)
Go here.
[link=http://www.widgetsupply.com/miva/merchant.mvc?]Widget Supply[/link]
I've bought from them many times especially for Dremel supplies & they won't rape you on shipping.
Hi Coop. Heres some pics of those magnetic cowl locks that I used on a Thunderbolt build I did last year. I got them from Herzog Racing via JRCBD and a lot of research. I added the black nylon straps underneath as pull handles to open the hatch. I'm not sure where to get a set of them these days. BUT, I just happen to have another complete set of them in my own personal building supplys.(less the nylon straps) Shoot me a message or an email, and we can talk about the perticulars if your interested. Brian
Would magnets be able to hold a hatch in place on a boat subjected to rough water? I run offshore in waves up to a foot.
Paul, If you grab the 2 nylon straps to release the magnets on the Thunderbolt cowl and lift slowly, you can lift the boat off the stand![X(] Do ya think thats strong enough for your rough water? Brian
Just to give you an idea of how strong rare earth magnets are. I have some AlNico magnets here for a project I was working on, these are not as strong as the much smaller radio shack magnets which are Neodymium. My larger, weaker AlNico's are about 5/16th in diameter and two of them are holding a carpenters hammer on the side of my steel filing cabinet. In fact if I let them stack together, the only way I can get them seperated is to slide them apart because I can NOT pull them apart!
IA
Thanks for the info and sites
Brian - I will send you message Monday am from work - thanks for the pics and help
Coop
Coop
Coop, No extra reinforcement needed on the set I installed. The fiberglass behind the magnets was 1/16"+, thick. Too bad the guy I built the Thunderbolt for has found a new love,, ATV's!! The boat rarely see's the water! Oh well[]..........................Brian
Coop, the magnet holds itself into a steel standoff that is threaded for a small bolt on the backside. Then a bolt thru the top of the cowl holds the standoff to the cowl. Look at the pics above again. Brian
YEP! Their kinda neet aren't they. But remember they won't work on every setup. You need a minimum of .375" space between the bottom of the cowl, and the top of the deck. Stuck together, they measure .360" thick. Brian
