Speed - RC Gas Boats Discuss gas RC boats right here!
rails
Old 02-24-2007, 08:10 PM
rogerp1
Default rails
when installing engine rails in to my 56 inch appache should i install some ply wood to reinforce the transom as i will be putting a rcm sterndive on the back of my boat ??
do i need to make the rails a special shape or will 1/4'' ply cut 2.5'' high be ok ?
Old 02-24-2007, 08:56 PM
Ultimate48
Ultimate48's Avatar
Default RE: rails
stringers and transom should look something like this
wood in this hull is over kill
1/4" will work fine.
make the transom strong for the RCM drive.
Steve
Old 02-24-2007, 10:57 PM
glennb2006
Default RE: rails
Here you go Roger, copied and pasted form another page - thanks to WayneUK for this. See links and all should becom perfectly clear.
"a hot glue gun works wonders in holding your rails in place while u fiberglass them in. aguy on here pointed me in the right direction as i asked the same question
http://www.rcuniverse.com/forum/m_49...tm.htm#4934279
http://modelgasboats.com/magazine/in...d=18&Itemid=47 "
Quote ends:
Regards,
Glenn
Old 02-24-2007, 11:59 PM
Flabum
Default RE: rails
As stated, 1/4" is fine. As for the shape of the stringers, that is dictated by the engine, you will need to shape the stringers as you install the engine. Just make sure all your shaping is long, soft currves so there is no place for a crack to start in the wood. 90 degree cuts in the wood is an invitation for fractures.
Adding ply to the transom really isn't necessary, but prudent. You could simply make a backing plate for the drive out of 1/8" Stainless Steel (I use dicarded restraunt pans and lids and cut them to shape) or aluminum.
Old 02-25-2007, 12:05 AM
dabo12367
Default RE: rails
Nice Build. Very solid and straight-foward. If I was to build my own rc at this point, you would have to forgive the copyright protection clause. David Barclay
Old 02-25-2007, 12:11 AM
Flabum
Default RE: rails
Yeah, I think Ultimate used a whole sheet of 3/4" ply in his
Old 02-25-2007, 12:51 AM
Ultimate48
Ultimate48's Avatar
Default RE: rails
ORIGINAL: Flabum
That is not my build, I found the pic's on the web.
http://imageevent.com/mrwigg/shaunsr...&c=4&m=24&p=24
Steve
