41 Falcon cat build
41 Falcon cat build
Here is some pics of a bit of progress.[img][/img]
Motor place ment is about 16 inches to the plug in the last pic wont knoe for sure untill the real pipe comes in and servos ect .
Jake
Jake
Banned
RE: 41 Falcon cat build
jake, here's some additional info on how to build a cat.
http://www.modelgasboats.com/Magazin..._Conquest.html
http://www.modelgasboats.com/Magazin...nsane_Cat.html
http://www.modelgasboats.com/Magazin...ducer_Cat.html
Banned
for a cat, 11-1/2" is a sweet length, I would measure it from center of the flange straight back to center of the band, wally runs the same pipe, he should know better of this pipe.
Cant wait to see your cat running mate. It looks if your putting all the go hard stuff in it. Im sort of new to these gas boats and the bug has hit me real hard. Good luck bloke.
I hope it will run hard Redline QD Hotpipe,SS full mod motor and 2716 W prop from Dasbota the go fast stuff is there well see.check out the thread titled 77 mph sprint cat video.
Your build is very nice should run pretty good allso dont think it takes much to get these lite hulls running good.
Jake
Jake
Jake the prop i got from dasboata is unbelievable i never seen anything like it its so sharp i can nearly shave hairs of my arm. Im sorta new to gas boats so i dont know if this is the norm but im very happy with his work. I saw the sprint cat vid it just makes you want one. very crazy i like it.
OK guys let me have it good bad or indiffrent i cut the cowl off now just need a good way to keep it on.[img][/img] still needs to be sanded ect its just rough cut rite now got rid of a lot of weight also.
Jake
Jake
ORIGINAL: jacob711
i think it looks ok, better than the standard one at least, i actually think it looks best without the cowl
Jake
Banned
jake, you might use a GPS to find out, if the cat runs faster with a cowl, just keep it on. for me, I really need a cowl to keep my cat's nose down, otherwise it will blow off sometimes when it catches the wind speed of 10-15 mph.
ORIGINAL: rcboateric
Jake
ORIGINAL: spudda308
Hey Jake, what sort of prop did you get from Dasboata, and that pipe looks very nice.
Jake
Banned
wow jake, you will have all the high end stuff such a full mod 260, 2716 fast cat prop and QD steel pipe for your cats, what speed of your cat would you expect?
Ummmm faster than 60 [:-] not sure but I am going to set them up so the motor and pipe will transfer from one to the other.At some point I would like to add a F41 Stryker to the list as well they make a nice drag cowl for it .I hope to get the falcon on the water in 2 weekends from now well see.
Jake
Jake
