BEST PROP
RE: BEST PROP
Mick,
I have always been given conflicting information for the Mathe 35 regarding best props. I have been told by Mathe to keep props smaller (70mm or so) as the motors need to rev. Others had been recommending 80mm props.
I have only limited run time with my 35 but found running the 7016/3 (same prop I run on mod zens and QD35's) to be a good starting point. It is a prop that you should have in your prop box anyway.
As mentioned - Chris (Dasboata) will certainly have some good options for you.
RE: BEST PROP
ORIGINAL: stoddy
mick you forgot to tell them its on a gearbox with counter rotating props.
Are the drives regular surface or stern drives (stern drives also have a gearbox).
Is it the Mathe C/R gearbox - if so what ratio is installed (they offer three options for ratio last I heard).
RE: BEST PROP
Hi Tony
This prop is for the mathe in a phamton not the no mercy, need to replace bearings in the gear box in the no mercy
RE: BEST PROP
Stoddy have you tried thisC R gearbox ?,looks like a good bit of kit and very reasonably priced this one went for under £60.I was considering it myself,he says shes been tested to upto 12 hp with no probs.I think he said he has the boxes made in Russia for them,company name is precision -in- perfection i believe ?
Mart
[link]http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=130322480085&ssPageName=STRK:MEWAX:IT[/link]
Mart
RE: BEST PROP
mart i would,nt if i were you. when i got back into boating this is the guy i stumbled across
and boy did i regret it razzfazzboats is nimrif models .but of course thats just my opinion it may be worth a punt at 60 .00
but everything i got from him was quickly moved on.
just bought a clutch with a gearbox from germany
from wd200 very nice bit of kit. they also just sell a gearbox both have counter rotating props but they are a bit pricey
