New To Gas Boating Need help
My Feedback: (59)
IN
I have A Warehouse Magnum 57 with a zen G260 engine with a clutch. It has A 75mm prop alum with A 105 pitch.
When I give it gas its reves up and throws a lot of water and moves slow at frist and it will get up to speed but it takes a 20 to 30 yards to do it[] Ahould I use a Brass Prop or am I useing the wrong size prop? Thanks for any help.
Tom
Tom
RE: New To Gas Boating Need help
You can go smaller on the prop but it sounds like the problem is in the clutch. It may need new shoes or just plain removed.
In stepping down on the prop, go to around 70mm. That would place less stress on the clutch and also get the boat out of the hole easier.
Yea what the last post said, Also if its the WHH spd 3 drive it's normal. My team pro also takes a bit to get on plane, Its a common issue with surface drive set-ups. If the clutch is slipping it will extend the time it takes to plane correctly.
Guess my question would be how she performs once she is out of the hole and up on the plane. Some boats take a little more effort to get up and running and some can take more work than others (depending on prop)
My super G has a great prop on her but still takes some effort to get up to speed
[youtube]http://www.youtube.com/watch?v=W7sPf0XCWO0[/youtube]
While my GTX takes a lot more effort
[youtube]http://www.youtube.com/watch?v=_7kMQu50H-I[/youtube]
My Feedback: (59)
IN
Hi ALL Thanks so much for all the coments, The vido is what my boat does so will try it tomrow morning.
Again THANKS TO ALL OF YOU I fell alot better now.
Thanks Tom
Thanks Tom
ORIGINAL: black talon
no guru by anymeans but wouldn't a slightly larger or more aggresive pitched prop get it out of the hole faster.
