Water pump?
RE: Water pump?
ORIGINAL: noahdear
you DON'T need one !!! Water pumps are a waste of money.
KS
RE: Water pump?
If you are running a clutch I beg to differ with Noahdear...if your boat sits and idles in the water or runs slower than "cruising speeds" to force water through it will burn it up to be sure.
Warehouse Hobbies
Bonzi Sports
ProBoat (actually makes a nice one with dual inlets/outlets)
Warehouse Hobbies
Bonzi Sports
MI
RE: Water pump?
i have the proboat pump. so far in about 10 hours of run time this year it has worked flawlessly. i think these pumps are pretty much all the same. its just a matter of preference. fwiw, i did buy the proboat one for the dual inlet/outlet. i cool my head separate from my exhaust.
RE: Water pump?
ORIGINAL: FlogginHarvey
If you are running a clutch I beg to differ with Noahdear...if your boat sits and idles in the water or runs slower than ''cruising speeds'' to force water through it will burn it up to be sure.
RE: Water pump?
Some of us like to let the boat idle on the water for a bit. And not to mention the safety factor of no prop cutting something , or worse someone , when you go to "throw" your rig in the water! I can take my eyes off of the boat and sit back, move my chair, get a drink, light a cigar etc. and not have to worry about the boat getting hot or where it's going! And i can idle her back to shore at my own pace. To each his own but if running a clutch I would always say get a water pump. It doesn't rob you of any power ( unless your into heat racing and every little bit helps ) so why not? The original question was which waterpump to go with so we know DFB is installing one anyways so hopefully his question is answered........
OK
RE: Water pump?
You guys are missing the point....he is asking who makes the best one....
Its not whether you "NEED" a water pump or not....we all know that if you are going to idle alot, it would behoove you to have one! Aaaannd we all know if you are NOT running a clutch you don't "NEED" one....Common sense...
Waste of money? Are you kidding? A 30$ water pump is alot cheaper than replacing a 250$ engine that got fried from idling with no pump..
My answer...I dont really know...I know alot are made by Walbro...I got the one from WHH and it is flawless..(forgot who makes it)
Cheers..
T-Daddy
Cheers..
T-Daddy
