Speed - RC Gas Boats Discuss gas RC boats right here!
wet sanding
Old 09-24-2009, 08:58 AM
pcg33k
pcg33k's Avatar
Default RE: wet sanding
do I need to wipe the water off when done wet standing or just let air dry?
Old 09-24-2009, 01:42 PM
misshydro
misshydro's Avatar
wipe the water off and let it air dry for 30 mins to fully dry out to get any moister out..then clear it.
Old 09-25-2009, 08:17 AM
pcg33k
pcg33k's Avatar
thanks misshydro I'll post more pics once I have wet sand and cleared it.
Old 09-27-2009, 02:39 PM
pcg33k
pcg33k's Avatar
Well the wet sanding didn't come out very good I don't know if I was using the wrong grit or sanded to long. I was using 1000 grit and I did it lightly but it seemed to come out like crap. I only did it on the canopy. I guess this is gonna take some practice I patched a hole in the canopy. I didn't like the way it looked I bought it used and the previous owner cut a hole just above the carb to allow air in. Here I go again sanding patching and priming.
Old 09-27-2009, 05:15 PM
pcg33k
pcg33k's Avatar
Ok here's the finished product. My first paint job its not professional by any means but at least the cracks and holes are fixed. I'm still working on the canopy I'll post some more pictures as I finish it. A couple pics are close ups and I added one of the inside of the hull. What do you guys use to clean up the inside of the hull?
ID:	1283582   Click image for larger version
ID:	1283583   Click image for larger version
ID:	1283584   Click image for larger version
ID:	1283585   Click image for larger version
ID:	1283586   Click image for larger version
ID:	1283587   Click image for larger version
ID:	1283588   Click image for larger version
Old 09-28-2009, 08:35 PM
  #31
misshydro
misshydro's Avatar
of over spray? use alittle lacqure on a rag to wip it out.. If its nitro oils then use simplegreen or purplepower.
Old 09-29-2009, 08:15 PM
  #32
pcg33k
pcg33k's Avatar
Its not over spray just dirt and fuel and grease. I was thinking of cleaning the inside of the hull and then maybe painting the inside or maybe laying some carbon fiber, maybe.
Old 09-30-2009, 04:56 AM
  #33
dicko
dicko's Avatar
ORIGINAL: pcg33k
1000 grit might be too fine/smooth to spray over, the paint won't bite onto that & may peel off easliy. I use 400 grit before I do my clear coat.
Old 09-30-2009, 10:49 PM
  #34
srt10
My Feedback: (20)
ORIGINAL: pcg33k
1000 grit is fine for color sanding, anything more like 800 or 400 will show some lines in the clear..
are you sanding the color paint or the clear?
In the past I sand only the clear and not the color paint, specialy on metalics
Old 10-02-2009, 12:06 PM
  #35
pcg33k
pcg33k's Avatar
i was sanding the color paint.
Old 10-02-2009, 07:58 PM
  #36
rcguy1411
dont want to hijack the thred bit i am at the same point as you as well do you get a better paint job when you colour sand then clear or can i just clear and then sand the clear this is mt ptoject thanks for any help
ID:	1287096   Click image for larger version
ID:	1287097   Click image for larger version
ID:	1287098   Click image for larger version
Old 10-02-2009, 09:53 PM
  #37
misshydro
misshydro's Avatar
just use a gray scotchbright pad to scuff the color them was the hull off with dish washing soap..then let it dry for ahour and tac the hull off with a tac cloth to get any dust off of the hull.
then put three-four coats of clear yhen wet sand it with 1500 wetsand paper them buff it out with buffing compound then machine glaze it then hand glaze it....DO NOT WAX THE BOAT FOR 90 DAYS!!!!!!!!! Paint isnt full cure until 90 days..if you wax it before then 90 days,the paint wont fully cure...
Old 10-03-2009, 08:51 PM
  #38
leebart121
off the wall question about wet sanding.
I use to work in a paint shop and noticed that after wet sanding, and buffing the cars paint job the painter would then put corn starch on the pad and buff the paint some more. What are they doing with the corn starch?
What effect will it have on a boats paint job?
Old 10-03-2009, 11:16 PM
  #39
misshydro
misshydro's Avatar
maybe to buff the finer scratches out...there stuff called miro finishing compound and fenessing compound too.......
Old 10-04-2009, 07:29 PM
  #40
pcg33k
pcg33k's Avatar
misshydro, I see you do painting for a living so you would be a good person to ask. I resanded the canopy because the first time I screwed up and I also wanted to fill in the hole that was cut out by the previous owner. After doing the patching and resanding I thought I had everything to a smooth finish but then I sprayed the primer and found some small spots that showed that everything was not to a smooth finish like I thought. What would be the best way to fill in these tiny imperfections?
Old 10-04-2009, 07:39 PM
  #41
LawHound
Pcg33k there is a Product called Spot putty sold in a tube that is used to fill small pits and imperfections in the finish be sure you allow plenty of time for it to dry (cure) before you start to sand it smooth it is found in a tube in most Auto parts House's it should do the trick for you. Doug.
Old 10-04-2009, 07:44 PM
  #42
pcg33k
pcg33k's Avatar
One more thing what would be the best way to paint the air scoops red and the rest of the canopy black. The first way I tried it didn't work out to good. Basically I taped off the air scoops then painted the canopy black then tried painting the air scoops red taping off around the air scoops once everything was dried. That didn't work out to good the red paint dripped onto the black. So I sanded and now I'm on my second attempt. Any suggestions?
Old 10-04-2009, 09:13 PM
  #43
LawHound
Spray the Scoop red let it dry fully then Mask it off and then paint the rest remove the masking tape as soon as possible so as to not leave any hard to remove tape residue and mess the red up again. Doug.
Old 10-04-2009, 09:20 PM
  #44
leebart121
I agree with LawHound. when I worked as a paint prep. that is what we did. We used a fine blue tape that we then would attach the masking tape and paper to. the blue tape was very skinny and had a plastic look and feel to it, but was very easily applied. it is the same tape used when a person pin stripes a car by hand to make a gide mark.
Old 10-04-2009, 09:22 PM
  #45
misshydro
misshydro's Avatar
Dont use spot puddy!!! It will shrink up in time and crack on you..I Use USC ICING... It's like mixing bondo but like a very light weigh pollester puddy and you can sand it with 180....Paint the scoops red first then tap the scoops off after four hours of dry time then paint the black...
Old 10-04-2009, 09:23 PM
  #46
pcg33k
pcg33k's Avatar
I think that's what I did wrong the first time I left the tape on for a long time and when I pulled it off it left some residue. Any particular technique I should use to mask off the scoops so as to not get any black paint on the red?
Old 10-04-2009, 09:29 PM
  #47
misshydro
misshydro's Avatar
heres three of my boats miss vegas and the two oberto's,,that I'd painted..was showing them off this year at celina r/c boat races..I'd use blue 3M fine line tape to do those boats with..
