That was stupid!!!!!
A buddy of mine just gave me his old .61 airplane engine to put on a air-boat I am building. Got it home secured it to a vise that is mounted on my work bench to try a needle I have. Started it up ran it for a couple seconds, reset the needle, ran it for another couple seconds and stop it. Reset the needle crank it up ran it for a few seconds, and just as I went to shut it down, the engine come off the vise, the prop worked its way across the top of my hand. Two hours later I am returning home from the hospital with 10 stitches. It was a deep nasty cut, could see the mussels in my hand move in the cut. My advise is don't trust a vise to hold down a engine with the prop on it, to do any settings. I will be building a stand that the engine can be bolted to.
Dad did one time tell me, Just because you get away with it a time or 2, don't mean it will not later come back to get you.
I have always preached safety.
Yup, it sure was! I have yet to hear anyone in the ER say that they did something really smart before they got in there and I've been in the ER plenty of times myself! I was in there recently (again) myself whe I was using a table saw at my sister's business cutting some foam for some sponsons. I was well aware of where the blade was but stuck my right thumb into it anyway! Luckily I just tore off a chunk off the tip but I'm still recovering.
See if Tatone is still making an engine testing stand. I used to have one years ago. Clamp or nail it to something heavy and solid so that nothing like this happens again. You now have a "reminder" but we'll still do something else stoopid. We can't help it, we're guys!
I had it in a vice, that is secure. Just after starting it 4 or 5 times the vice got lose from the vibration and pushing on it with the starter. At least the best part, on the last start up, I had gotten the needle where I wanted it. Now I just have to get the wife, to stop being mad about my hobby....LOL
Talking about the table saws, my sister thought for sure that my table saw got me. I have a lot of respect for the table saw, even though I removed the guard.
Ron what type of foam are you using in your sponsons? I have not been using any, just been fitting the wood, and it gets to be a pain doing this way, trying to keep the twist out of it.
Thanks guys
Thanks guys
My Feedback: (46)
Believe me I understand what happened to you. I mounted a fox 52cc gas engine to a 4x4 post in the ground to test run the engine, It had a 20x10 mejzlik prop on it, after some adjusting & priming I got it running, I started throttling up until it was just about peaked & three of the screws holding the engine to the post pulled out. the engine swung really fast away from me & broke the last screw, it fell to the ground killing the engine. Luckily it swung away from where I was standing & I didn't get hurt, as a matter of fact neither did the engine or prop. I guess I was very lucky. After that I drilled some holes completely through the post & used some long bolts with washers & double nuts to test the engine. I wish you would have been as lucky as I was.
Gil
Gil
I was using some 2" pink foam for the sponsons. It works pretty good but the next time I'm going to get some blue. BTW, I'm going to invest in a hot wire cutter so that I can just burn myself instead.
In our kit, we're using 1/8" balsa attached to the foam with double-sided tape on the sides then use a thin layer of epoxy to 1/32" lite ply skins all around.
