Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
 is it normal.. >
is it normal..
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
is it normal..
Old 10-13-2003 | 01:11 AM
550racer's Avatar
Default is it normal..
..to have after u fuel up ur tank the fuel to start moving along the line to the carb? is it bad or its ok? i got a hemo to pinch off the line till im ready to start it..
Old 10-13-2003 | 02:20 AM
Default RE: is it normal..
it shouldn't matter. usually it is an a*s to get guel to the engine.
Old 10-13-2003 | 06:11 AM
Ron Olson's Avatar
If the tank sits as high or higher than the carb, it's gravity at work. The same problem I'm having with one of my boats at the moment.
Old 10-14-2003 | 11:53 PM
Is it bad to have fuel flowing to the carb before you even start priming?
Old 10-15-2003 | 12:27 AM
550racer's Avatar
i was havin the same prob with the stock tank i didnt even need to prime it it alredy went to the carb as i was fillin it thats y it was flooding cuz it filled up the engine so i hope the hemo trick works..
Old 10-15-2003 | 10:39 AM
It appears to me that you are filling the tank through the pressure/vent line with the supply to the carb still connected. If that's the case, then you are building pressure in the tank due to the fuel coming in and pushing it into the carb. Try filling the tank from the supply line to the carb and let the pressure/vent line be the over flow.
