engine swap
My Feedback: (34)
RE: engine swap
As long as it is not run with a cowl and you don't use too high a nitro it can be done and will work. Needle settings are the key, NOT LEAN to cause heat build up. The cool circulating in the boat off the water will work fine and possibly better than in a car.
Regard Curt
Regard Curt
RE: engine swap
I'm running a Buggy .18 in a deep vee hull now for 3 years.....no problem, and it's in a cowl. I'm using 30% nitro. It moves really fast. Everyone is amazed. Pity there is no .18 category in the IMPBA for I would have a few plaques.
This year some of the guys in my club are running Buggy engines in riggers etc.......
RE: engine swap
I've been running some .12 motors in a few of my little boats. The IMPBA upped the motor size for the "A" class and there has been a lot of interest in it but no races have been actually run yet that I know of with this class. As long as they get plenty of air you shouldn't have any problems.
RE: engine swap
If your worried about it over heating a company called Klampz sells a wrap along water cooled header one size fits all you can use. Or make your own with brass tubing.
