Go Back  RCU Forums > RC Boats > Speed - RC Nitro Boats
 Bigger Engine? >
Bigger Engine?
Speed - RC Nitro Boats For all your rc nitro fuel burning boating needs.
Bigger Engine?
Old 08-01-2004 | 03:34 AM
Default Bigger Engine?
i was thinking and i whated to know what would happen if i put a .21 engine in my Nitro Hammer. would it raddle the boat and make the hull crack? or not do anything at all? how much faster would it make it go? what about a .18?
i was looking at a .21 engine something like this:
http://img.photobucket.com/albums/v57/rg501/engine.jpg
^ would that fit? would i have to make a water cooling head or could i use the one that is already on my NH?
Old 08-01-2004 | 09:14 AM
pflumitch's Avatar
Default RE: Bigger Engine?
why not try something like [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&W=000411384&I=LXALL9&P=K]this [/link]
Old 08-01-2004 | 01:04 PM
sweet. but if i put that in my NH, would it raddle it up too much and break the hull?
Old 08-01-2004 | 01:15 PM
and also would i be able to use my stock tuned pipe or would i have to buy another one?
what the diffrence between the one you showed me and this one: http://www2.towerhobbies.com/cgi-bin...?&I=LXALL8&P=0
Old 08-01-2004 | 01:56 PM
pflumitch's Avatar
The one i showed ya is the same as the one your looking at, except One comes with a recoil starter. I would highly recommend a new tuned pipe for the powerplant. Your Nitro Hammer should be able to handle it, only thing is that i would look at upgrading your prop to a nice new Octra prop.
Old 08-01-2004 | 03:31 PM
Ron Olson's Avatar
OK, where do I start? The hull might take the extra power for a while but it's pretty thin for any serious .21 motor. You'd have to modify the motor mount. The driveline should be upgraded also as the little 1/8" shaft ain't gonna get it. You won't be able to put a large prop under the hull that you're going to need. Converting to a surface drive set-up would be he next step. Yeah, you'll have to toss the tuned pipe out with the motor. don't forget to install a larger fuel tank, you'll want 8-10 oz. in there.
The radio box should be fine if that helps at all.
Alternative. Get a killer .12-.18 motor and it'll bolt right in. Just remember, fully threaded crank and rotary carb then get plenty of air to the heat-sink.
Old 08-02-2004 | 11:49 AM
wow. so i guess i'll get a .18. i was looking at the Cen NX-18. i think that will be a good one for my NH. i need a new tuned pipe if i get the engine. what one would you suggest?
Old 08-02-2004 | 03:28 PM
Ron Olson's Avatar
You'll be disappointed with the CEN .18 as it's actually slower than what you have. It's only rated at around 21,000 RPM. An O.S. .18 might do the trick as it has the fully threaded crank, pull-start and rotary carb but it's air-cooled. My LHS is selling them for $130.00, not too bad.
Old 08-02-2004 | 05:13 PM
ok thanks ron. sense its air cooled, will it burn up or something?
Old 08-02-2004 | 08:17 PM
Ron Olson's Avatar
As long as you can get a decent flow of air to it, there shouldn't be any problem. Keep in mind that not a lot of cool air goes through a car or truck body.
Old 08-02-2004 | 08:55 PM
so what your saying is that cars and trucks sometimes dont get good cool air flow and sometimes my boat wont, so it should be good?
Old 08-02-2004 | 09:03 PM
I'd still put in a air scoop, by the way, which hobby shop do you go to near flushing. (I you live in flushing because I see it under your name )
Old 08-02-2004 | 10:20 PM
ok. then if i do get that new engine, i'll put a air scoop in it. i go to Ryder's Hobby Shop in Flint. where do you go?
Old 08-03-2004 | 09:59 AM
I go to the riders hobby shop in grand rapids, but I've been to the one in flint, Right now Riders Hobby shop in Grand Rapids has no nitro boats so I have to wait to buy one.
Old 08-03-2004 | 04:18 PM
yeah, the hobby shops around here dont have much boat stuff. but they have some stuff.
