K&B 3.5 Help
NC
RE: K&B 3.5 Help
Hey Nick,
According to the instruction sheet and the K&B outboard motor that I have... a 8906. K&B recommends 4 to 4 1/2 turns out at sea level. This is a starting point.
RE: K&B 3.5 Help
Not certain how above sea level I am, can check later when I get home with the GPS.. When I first started running the SS, it started out around 4 +/- turns out. It then started to always die at bouy 4.. It took a few more runs to determine that the motor was way too hot. I do believe the last time I checked the needle, it was 5 1/4 out.. Sounds rich, but that motor loves fuel..
Last item, what % of fuel are you using? This can make a difference. I'm always running 65% in my boats.
